Results 1 to 7 of 7
Thread: Driveline Vibration
    VS Calais
    Dec 2008
    Default Driveline Vibration
    Hey
    Can somebody help? I've got an auto series 1 VS Calais V6, with a slight vibration, its always been there, it only appears when accelerating from a standing start, at around 1500 to 2000 rpm. Ive had the auto box rebuilt and ballanced the tailshaft, its not in the wheels, tyres or brakes as they have all been changed and the vibration still there.
    Anybody got the same problem, or know what it may be?
    Thanks Dave
    V-Josh-R.'s Avatar
    V-Josh-R. is offline NEED PACEMAKERS.
    94-VR Commodore Ute
    Jul 2008
    Discs need machining? Did they do an alignment and balance on the new wheels? Could be many things...
    Holdens go fast...very fast.
    FORD:
    First
    On
    Rubbish
    Dump
    :P
    S> CLEAR REAR BRAKE/TAIL LIGHT UNITS ( Got both left and right, from a VR ute),GOOD CONDITION, $70PICK UP ONLY 2197 N.S.W. PM ME
    Haydz's Avatar
    Haydz is online now Fasten your seatbelts
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    could also be the shocks.
    my rear shocks were rat ****. then i replaced them and it cured alot of my noises/vibrations.
    just a thought maybe you should check them
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Really you can spend heaps trying to get rid of the very common vibration as described. Some cars respond to a fix whilst others retain it no matter what is replaced. Mine has it and I know that all driveline components are A1 so I just live with it. Actually I sort of like it as it feels like an aircraft when they power on to takeoff.
    VZ SV6
    Oct 2008
    Newcastle NSW
    Could be the torque converter distorted as it would cause vibrations when accelerating, or engine mounts...
    mrhotdog is offline What Would Jesus Do?.....
    2003 VY S1 Acclaim
    Nov 2007
    Adelaide, South Australia
    on the note of shockers and mounts, how much do u reckon new shocks would cost (nothing fancy) for front as mech said they r 'soft' when bushes got done. also would doing the engine mounts be an expensive job or hard if DIY?
    VS ACCLAIM S WAGON
    Mar 2005
    Default sholly
    Hi Dave
    Got the same problem with VS S/W V6 355k.
    The auto transmission guy replaced the rear mount and removed some vibes but hasn't done the fronts as more difficult to get at.
    As they get older the mounts get harder.
    sholly
  1. Vn Driveline Backlash
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2009, 05:32 PM
  2. VN Driveline into VK
    By Pav in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-02-2008, 10:16 PM
  3. driveline clunk vy
    By vs hay hauler in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-04-2007, 06:06 PM
  4. Problem with VN driveline
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2004, 02:03 PM
  5. Driveline vibration
    By Bulldog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2004, 12:02 AM
