Results 1 to 19 of 19
Thread: supercharger on/off?
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default supercharger on/off?
    guts a quick question
    can you rig a super charger so you can turn it off and on?
    or do you just use a boost controler to control how much boost your on (ie to save gas set it to a low boost, and to go fast use i high boost) - basicly the same as turning it off or on?
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by PSYKO PHOENIX View Post
    Have you just finished watching Mad Max ??
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Nov 2008
    rotorua, NZ
    hahahaha na, a friend said it was possible, i just wanted to make sure lol
    you power it down!
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    yes it is, that is infact how the SC14 works, do a search on SC14 about 10 million threads.
    They work allot like a or exactly like an air conditioner clutch (Electronic)
    Nov 2008
    rotorua, NZ
    i found this
    The SC14 Supercharger Thread
    and this
    http://www.rodshop.com.au/superchargerholdv6.htm
    figurd id post it up so if any one was in the same boat as me they wont have to search to far :-)
    you power it down!
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    As stated, Sc14 and the like have a clutch to engage and disengage the supercharger.. nothing aftermarket is available to adapt to any other superchargers to my knowledge.
    And the only way to adjust the boost generated on a supercharger is by changing the pulley on the front, the smaller the diameter of the pulley the higher boost pressure generated.
    Nov 2008
    rotorua, NZ
    sweet, another dumb question, is the amount of boost form a supercharger more powerfull than a turbo? i know they both run in psi, what i mean is say a supercharger is running 10psi is that equivilent to 15 psi from a turbo, or am i just being a moron
    one of my mates keeps craping on about how his subaru is rinning 20psi, my commodore is already close to his amount of horsepower and its naturaly asperated, im obviously not gunna need a lot of boost but im just curious weather the 2 types of boost (supercharged and turbo) have any differance in the psi generated
    and before you tell me i allready know that turbos have to spool up creating turbo lag etc and that superchargers are run off the crank shaft and so have no spool time, making them better allround
    sorry to be a dumb a$$
    you power it down!
    Jun 2005
    how does a v6 n/a have similar power to a 20 psi subaru? turbos are a more efficient form of power compared to superchargers
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by stocky View Post
    not quite sure, i havent seen the amount of boost hes runing, he wont let me, he CLAIMS its 20psi but its a stock turbo, i doubt its that high
    all i can tell you is that my commy has no problem keeping up/passin his 4 cylinder ass,
    and hes not the kinda guy to go easy on the gas
    you power it down!
    VT spac super6
    Nov 2008
    Riverton sa
    his must be f*cked lol
    a supercharger will give you constant power soon as you want if right from idle..
    turbo needs so many revs to produce the exhaust pressure to spin the turbine and the load on the motor to hit full boost
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by harvy1 View Post
    right and wrong. a PD (positive displacement) blower will give a almost consistent boost pressure from low rpm as in the L67 setup. a centrifugal style blower will build boost with rpm i.e. it starts makingboost at say about 2500rpm and is making 10psi at about 5500rpm. i.e a raptor style blowers. blowers drive of the crank and obviously require engine power to create boost. turbos on the other hand make free power because they use the spent exhaust gasses. where and when a turbo boosts has to do with the the turbo used i.e. the the size of the turbine and exhaust housings. a properly spec'd turbo will produce boost with very little lag.
    to change the boost on a supercharger you need to chagne pullies as mentioned above, with a turbo all you need a boost controller.......
    turbo setups are a lot more involved then superchargers............
    i honestly wouldn't bother with a sc14 setup. they are in-efficient and if you want more then the standard 3psi you get on a 3.8 V6 you loose the abilitity to swith it on/off mad max styles. 3psi is really stuff all boost anyways
    Body by Holden, Soul by Brock
    the Legend will live forever
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by immortality View Post
    now thats what i was lookin 4!!!! i p!ss harder than 3psi so i definatly wont be getting one of those! is the sc14 the only one with an on off switch? can a clutch be built onto any supercharger?
    the reason i want an on off is because i dont want to be running boost all the time, only when i need it
    thanks for all your input and help
    you power it down!
    sle turbo is offline vc sle turbo
    vc sle
    Dec 2008
    maryborough qld
    use a toyota 4agze supercharger they have electronic clutches
    vc sle
    Dec 2008
    maryborough qld
    Default vc sle turbo
    buddy a super charger works on rpm where as a turbo works on load but it depends on the flow rate that creates power what flows more pouring water down a 20 mm pipe or dowm a 70 mm pipe
  15. #15
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    What Subaru does he own?
    A WRX fitted with a Vf34 could push 20psi. But its running out of its efficiency range at around 18psi.
    Even still, an Ej20-t GC8 WRX fitted with a Vf34 running 18psi would be making around 170-190kw@aw. That combined with a 4.11 final drive, I REALLY doubt you're keeping up with it at anything under the speedlimit.
  16. #16
    Apr 2006
    Auckland NZ
    the SC14 aka 4agze is hte only one that can be switched on/off
    with a raptor style centrifugal charger it won't start to boost until about 2500rpm so unless you have 4.11:1 ratio diff fitted you won't ever be cruising with it wanting to boost. raptor setups are returning fuel economy figures that are almost as good as factory quoted figures...... thats good enough for me..........
  17. #17
    radarak47's Avatar
    radarak47 is offline I lean to the right
    VXII Acclaim
    Jun 2008
    Sydney NSW
    There are setups in the states that run Centrifugal blowers with pulleys at near max efficiency then a wastegate between the blower and TB to limit the max boost in the manifold.
    Lots of pros and cons to this type of setup but if you want adjustable boost on this style of SC it is possible (just expensive, with a lot of trial and error to get it right.).
    Pros:
    you can run less boost on the street and then up the boost for that tyre frying run.
    Boost will always come on lower in the revs i.e. 1500 rpm and max boost (achieved by the wastegate setting) will be acheived through mid range instead of peak rpm.
    Cons:
    Lot more heat generated from the blower (so intercooling is a must)
    More parasitic loss from the blower as it is working harder all of the time, even with manifold boost limited by the wastegate.
    Setting up the MAF after the wastegate or have to have a plumb back wastegate otherwise metored air from the MAF will read wrong causing motor to run too rich or lean. Only other option is an aftermarket computer with MAFless tune.
  18. #18
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by soop View Post
    who said anything about a speed limit, lol
    you power it down!
  19. #19
    vr statesman 5.0
    Jan 2009
    have a look at sta chargers mate,my mate had one that has an on/off switch in his vs wagon.
  1. vn supercharger
    By somerandom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2009, 12:46 PM
  2. Supercharger M90
    By RVN 355 in forum V6 Development And Modification
    Last Post: 09-02-2008, 04:56 PM
  3. WHAT Supercharger can I get for 304 V8?
    By sixes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2006, 10:14 PM
  4. vs v6 supercharger
    By danny1987 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 10:10 PM
  5. Supercharger??
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2005, 12:12 AM
