On my drivers door of my VS one of the rivets has broken that holds the regulator. The window tips over when I try to use it. The regulator flex's etc when I use it. Is there an easy way to fix this?
Your local holden dealership should be able to supply you with the correct rivits, also while your there change the white window sliders as they will fail soon also, might as well do it all at once.
[SIGPIC][/SIGPIC]
Have you had this problem to? Is it hard to fix?
My issue is the regulator has bent a bit and the broken rivet hole does not line up with the hole in the door.
I did the front windows in the Senator.
I replaced all the rivets with bolts and nylon nuts.
The regulator was moving, rivets not that far from braking.
Have you had a look at the actual door, behind the trim?
Is it able to be bent back?
I'd try and bend it back and use boltsto replace the rivets.
Check the pass side to see what it should look like.
Also as seannatt said while your goin, replace the felt slides for the glass, makes heaps of difference.
Stoke my ego, click the scales!!!
Stoke it!!!!
LOVE IT!!!!!
Ive just been told by my Holden dealer to use self tapping screws. Thats sounds dodgy.
when i replaced the window reg on my vl back in the day, the place gave me screws instead, had to drill out the rivets to remove crapped reg. i guess diy screws are easier than finding a large rivet gun.
If 1 rivet is broken, & the window is creeping out of alignment, then i would guess there are more than 1 broken.
The rivet head may still be in the door, but it's broken.
I have used stainless rivets this time, with a washer.
Cheers, Col.
when i converted to elec windows, i bolted all my regs up with 5mm bolts i think they where bout 20mm long
it can be a prick to get to some but its very doable.
Go the nuts and bolts bro.
you will never touch them again.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
The rivets arent just any ordinary rivets either, you would have a hard time finding the tool to punch them in. Im another for nut and bolt. Cant remember exactly what size, just went the largest that would fit in the existing hole nicely. That was a while ago and shes still working as good as new.
dont worry, il start a ride thread soon.
