Results 1 to 6 of 6
Thread: Ignition advice
    manta 42 is offline manta man
    vs hsv manta
    Nov 2008
    south coast
    Default Ignition advice
    i have a vs manta with the 5L in it and it seems to be blowin up the ignition module all the time. ive had all the leads , spark plugs, dissy, coil replaced and even the battery but it still seems to do it. and i dont know why
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    check the harness to see if any wires have been rubbing and have become exposed, could be shorting out?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    either that or your having a bad run on second hand moduals if thats what your buying
    Reaper
    vs hsv manta
    Nov 2008
    south coast
    I had a look around and I can’t really find any exposed wires. And its done it 5 times now the first 3 times I had them replaced with a brand new genuine one but the last two I just got 2nd hand ones, I had an auto election look at it but he seems to think that do it if you drive them hard it will burn them out. Witch I don’t do often so im going to look at getting a whole new ignition system something after market. Any ideas?
    VR 5.0L
    Aug 2008
    Crane do the HI6 to by pass the standard ignition module pt no. 6000-6445.
    Try outlaw speed shop, that part no. includes coil as well for $610.
    Only spoke to crane and outlaw about a week ago.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by manta 42 View Post
    Put simply, the auto electrician is a fool. Plenty of V8s around that get thrashed within an inch of their lives without having any ignition module problems. In general the modules are very reliable and perform better than a lot of after market products. There have been posts about the modules being subject to heat deterioration and also about the short life of some repaired modules. Your experience with successive failures (even with new modules) is very abnormal and points to the modules being 'killed' by something outside of the modules themselves.
    Send a PM to Doctor Bob, he may be able to help you.
  1. Some very bad pre-ignition on VN V6
    By mike_nofx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2009, 02:29 PM
  2. vk ignition
    By nezza in forum Electrical Wiring / Questions
    Last Post: 06-02-2009, 02:27 PM
  3. vp v6 msd ignition
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2009, 02:24 PM
  4. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  5. Advice - botched key cutting - stuffed ignition
    By vh-holden in forum General
    Last Post: 20-12-2005, 09:18 PM
