Results 1 to 7 of 7
Thread: Fun Clunking Times
    Grennan's Avatar
    Grennan is online now Slayer of Stupid Threads
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    Default Fun Clunking Times
    Ok... yet another clunking problem that needs to be solved. Driving home from a mates place I stopped at the lights. Upon the lights turning green I put the foot on the accelerater and it doesnt really seem to move to fast. As soon as it got to about 3000 rpm there would be somewhat of a jerk from the rear along with the lovely clunking sound and it would drive perfectly, untill you stopped at the next set of traffic lights and it would occur again.
    Had two people suggest uni joints may be going going and gone... as well as perhaps the center bearing and ive had someone suggest that it may also be a torque converter issue.
    Any ideas?
    - Black Manual VX SS Series II -
    Stealth Mode Activated
    Morton's Avatar
    Fairstar the Funship
    May 2006
    If it's not really moving, it sounds like a torque converter. A bad uni will still put power down.
    The 1972 HQ Kingswood
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Have you given the center bearing a shake to see if its ok.
    Reaper
    Grennan's Avatar
    Manual VX SS SII
    Mar 2007
    Nah im gonna get under there tomorrow and have a real good look, had a mate from this site come over today and he had a quick look and he said the center bearing looks like its a little worse for wear as well as the uni joints so ill get under there when i can find some ramps that will go under my car.
    Would the center bearing cause me to crawl at the lights though?
    My mate/mech is currently on holiday and work is giving me no shifts, great timing.
    Morton's Avatar
    May 2006
    Torque converter is easy enough to change if you have a spare day and the right tools.
    Essentially you just drop the transmission down, and then pull the torque converter out Then slide the new one in, spinning it around 'till it clunks three times.
    Then fill up with fluid and you're set.
    VT spac super6
    Nov 2008
    Riverton sa
    does the engine sound like its loading up heaps when you go to take off?
    could be brakes locking on...
  1. Clunking, anybody help?
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2008, 05:21 PM
  2. help, help, help, help Clunking VX
    By shaun100 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2008, 10:45 AM
  3. Clunking Problem at about 75-78 Kms
    By benim2000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2007, 05:40 PM
  4. Clunking
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2007, 05:06 PM
  5. Clunking Through The Gears
    By Robbie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2004, 03:13 PM
