Results 1 to 22 of 22
Thread: VR 1994 Cuts out around corners
    vr commodore
    Dec 2008
    Default VR 1994 Cuts out around corners
    Hi Everyone,
    I have a 94 vr sedan and I have just put in a new fuel pump and fuel filter to fix an ongoing problem. But its not FIXED.
    When i have less than half a tank and drive around any corner (at normal speed) the car seem sto lose all power for a few seconds (which causes other cars to get very close to my reaer end!!) then i am left madly pumping the pedal and in a few seconds the car springs back to life and continues on.
    I thought that the fuel pump might be faulty so i replaced it- but still have the same problem - I also have really poor fuel mileage about 340k for a tank
    I would appreciate any assistance or feed back
    Thanks
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by justin wong View Post
    Hi Everyone,
    Thanks
    I'd be checking the connections on the battery, make sure they are clean, secure and tight. I'd be checking your oxygen sensors to make sure they are working correctly, as well as checking fuel pressure. Another sensor to check is the coolant temperature sensor, if this is giving a false reading the engine will be running too rich. Also check that your thermostat isn't stuck open; where does your temp gauge normally sit? Depending on the mileage your car has done it might be worth pulling the injectors out and getting them professionally cleaned too.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    pffft, nah, it'll just be fuel surge...
    Have no idea how to fix it other than a surge tank setup.. its been covered on here before though, a few times... have a search around
    aZk.
    VH SLe/VR Wagon
    Sep 2008
    I have a VR wagon that was doing the samething i put it on the tech 1 and it had a Crank angle sensor fault so i changed it and its all good now. I would be checking that i had the same issues, car would just die and not start again with out pumping the accelerator and hoping it would fire. Make sure you disconnect the battery at the start of the job because i could be wrong but the bcm needs to be reset to read new sensor. I changed mine and it hadnt fixed it then disconnected the battery for 5 mins and it runs perfectly...
    Hope this helps...
    [SIGPIC][/SIGPIC]
    Oct 2007
    its probable the line off the fuel pump that feeds the swirl pot mine does the same thing when under half a tank except the line for my swirl pot is attached
    Morton's Avatar
    Fairstar the Funship
    May 2006
    My mate's VR does this too. The baffles in the fuel tanks probably break
    The 1972 HQ Kingswood
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Id say it would be that swirl pot line too, if not its a good one too look at anywayz. If its not on the fuel pump will starve around corners
    Reaper
    vr commodore
    Dec 2008
    Hi Everyone,
    Thaks for the comments. I now think that it will be the swirl pot or the line that connects it. Can the swirl pot be re-aligned wihtout the tank being removed or will i need to replace the whole tank and hope for the best.
    Does anybody in Brissie have a vr or vs tank for sale?
    Oct 2007
    the line can be but back on but it has probably gone inside the tank and id say you will have to remove the tank to reconnect it
    VR 5.0L
    Aug 2008
    I had the exact problem only a few weeks ago in my VR , the only way I solved it was replaced the tank then it was perfect again.
    vr commodore
    Dec 2008
    Default Hello
    Hi
    Did you replace the tank yourself or did you pay a mechanic ?
    vs commodore wagon
    Dec 2008
    Thats my next job.Ive had it for 7 yrs.Pain in the ass.New fuel pump and fuel filter as well.
    VRII Acclaim
    Jul 2005
    Tank is fairly easy to get out, hardest part is getting the fuel out of the tank first. Once you have that done things are fairly easy, just take a bit of time.
    Guys above are right though, return line that feeds into the swirl pot. Someone put a great write up about exactly what is happening, usually only when the fuel tank is below 1/4 full.
    VR 5.0L
    Aug 2008
    I done it myself although I do everything myself as mechanics charge way to much lol. The only thing I would recomend is changing the big breather line that goes to the fuel neck to a more flexible line (heater hose I used)as the factory pipe is stiff as and an absolute pain in the A$$ to get back in.
  15. #15
    VP Executive R-spec
    Jan 2005
    The swirl pot in the tank can break loose and cause this. It's pretty common and unless you know a danger man engineer that de fuels and welds tanks your best to just replace the tank. Don't try and fix/weld a broken tank at home because you will most likely die from the resulting explosion :0
  16. #16
    Oct 2007
    Quote Originally Posted by greenfoam View Post
    true i didnt even think of that! looks like im getting another tank what should i be paying for one second hand?
  17. #17
    Jun 2005
    where are you from. i know in melbourne at pick a part a tank costs about $40
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
  18. #18
    VR 5.0L
    Aug 2008
    Oct 2007
  20. #20
    gsxrdan's Avatar
    gsxrdan is offline Has this got a turbo?!
    93 VP Excec; 95 II VR Equipe; 99 VT Exec
    Dec 2008
    adelaide, southish
    Aargh - mine stalled for the first time last night... has been hesitating a bit when i put the foot down but last night going round a round a bout i thought id see if it would hesitate (like when in have an injury, i have to poke it and make it hurt every now and then just to see what its like again!!!) and it stalled out and i had to pull over cause it wouldnt fire untill it was in 'P'... is there any test i can do to verify swirl pot issue?
  21. #21
    Cammed mafless VS Calais 5-speed.
    Dec 2008
  22. #22
    vr commodore
    Dec 2008
    Hi Stocky I am in Brisbane- but I have called the wreckers and they advise 65.00. Is there any sure way to check if the swirl pot has actually broken inside the tank ???Before i but another.
  1. Power steer cuts out then cuts back in!!!!
    By fnlow1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2008, 01:03 PM
  2. Losing power around corners
    By Woules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-02-2008, 12:06 AM
  3. 4 Corners 'Peak Oil'
    By Cheap6 in forum General
    Last Post: 09-08-2006, 12:23 PM
  4. Lack of engine power around corners??
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2006, 11:05 PM
  5. Power loss around corners
    By smau in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2005, 08:34 PM
