Results 1 to 8 of 8
Thread: Help changing v8 alternater belt
    vs ute
    Dec 2008
    Unhappy Help changing v8 alternater belt
    Can someone help? The alternater belt on my vs v8 is worn but to get to it i would first have to remove the power steering belt. Problem is , i cant see what bolt to loosen to allow some slack to take it off. Does anyone have an answer. Thanks
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I gotta do mine too, doing all of them tomorrow actually. But to get tension on the alternator belt you gotta use a small bar to pull the alternator out nice and tight or it will squeel.
    Last edited by VrWagz1; 30-01-2009 at 11:42 AM. Reason: cause i hit edit instead of quote and stuffed it up:S
    Reaper
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    There are three nuts that need to be loosened on the power steering pump attaching bracket. Two are adjusting nuts and the other is where the earth strap attaches. See diagram below.
    vs ute
    Dec 2008
    VR Exec
    Dec 2008
    Penrith, Sydney
    Smile thanx for the dia
    hey mate thanx heaps for the diagram im just a newbie to the v8 range and my fan belt flew off in getting the VS SS home and the bloke said that it was about to go so and he was right and now i WAS having trouble thanx for the help.
    VrWagz1's Avatar
    May 2008
    wollongong
    VrWagz1 I gotta do mine too, doing all of them tomorrow actually.
    I still gotta do mine, i never got time that day. Belts still sitting in the kitchen
    Reaper
    vn commodore
    Jun 2009
    Cool
    hi folks just wondering if anyone has a diagram of vn 6cyl power steering diagram thanks heaps.ED
    VrWagz1's Avatar
    May 2008
    wollongong
    no, but nice dig....I'll add that i have done my drive belts and what a releif, they are so much quieter. Power steering was a bitch to adjust, laid under the car with a bar in one hand and a ratchet with extension in the other jammed up and in there somwhere trying to get tension on the pump and tightening a bolt to hold it at the same time. The alternator belt has stretched a poofteenth and it needs tightening again as it squeels when you free rev the engine and at the second the engine kicks when you start it.
    Reaper
  1. how long before changing cam belt
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-12-2008, 09:21 PM
  2. Help with Noise after changing timing belt....
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-12-2008, 01:48 PM
  3. Changing Timming Chain/Belt on S1 VN V6 motor
    By deafnu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2006, 06:00 AM
  4. any tips on changing a serpentine belt
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 05:52 PM
  5. changing drive belt on VT 5.7
    By xtr041947 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2005, 08:44 PM
