Gday again fellas.Anyone got an idea of what sort of adhesive i can stick my roof lining back on with? Seen heaps of VR/VS sedans and wagons with hanging roof liners.Another repair. Thanks again.
Your lucky im up late too
HOW TO replace headlining - Very detailed
Dont use spray on glue, it sucks mine just fell down again a few weeks later, not as bad as before but still. Go to clark rubber or similar and but some of the rooflining stuff they got, thats what ill do next time.
The Daily VN T5V6
355 VN GRP A REP
i have same problem, there is only 1 solution and that is to take it out, clean lining board of all rubbish, and redo it. other than that, i found thumb tacks work a treat, look ok, and cost about $4.00 all up.
Pull it out ,clean the board ,get some material from spotlight with a medium stretch( track suit type material works the best) not light,thin or the original crap,use spray adhesive plenty of it for the main part spray on both material and board and a thick and tacky glue( in a tube) for the edges ,do it all in the sun so everything is warm
We have done two of hoodlings like this and they are nicer and plusher than the originals if I new how to post I would show you the finished product
the cost on average was about $15- $20
i hope these photos work out
One more thing its nearly impossible to stick the original material and glue will soak through leaving stains and it will always evently sag again, especially when its cold or raining
My house mate put 57 staples in his roof lining to get it off defect and its stayed like that for 2 months now![]()
