Hey guys,
Im new to being a member here but have used your site for countless pieces of information so I thought I would join. Just bought a cold air intake from local holden dealer and have installed it, my next challenge is which air filter to buy. I was going to get a K&N but a guy form work told me to just make my own out of a wire frame and a stocking. Currently Im using a wire frame with 4 layers of stocking, and honestly I am impressed there is no restricition on air flow at all and it made a considerable difference to throttle response and acceleration. Also I have a backup plastic mesh covering the intake hose in the box above the filter in case the stocking flies off and tries to go straight into my engine. Now I know people say that dust and crap will get into my engine but I dont drive in dusty conditions, and cmon $85 for a K&N, I got my entire CAI setup for a mere $65. And the olnly difference between a stock air filter and a K&N is that K&N is high flow, but my stocking will be way more high flow. Just want to know what you guys think....
Sounds pretty good for a quick cheap gain, I probably wouldn't use it too long term though. Once the elastic in the stockings are shagged the fabric is going to fall to bits and not give you a lot of filtration.
Do you have any pics of your work? I guess if you made it well enough then you shouldnt have too many problems... if the stockings are fine enough to clean up dust from the air. Its probably a good idea to cover it with k&n filter oil to make sure that all the dirt sticks to it properly and it doesn't work its way though eventually.
*** FOR SALE ***
4.2L Buick V6 Billet Stroker - Built for big boost
HUGE $$$$ SPENT - Selling well under half of the build cost
http://cgi.ebay.com.au/ws/eBayISAPI....STRK:MESELX:IT
Good idea with the stocking.
I used the how to and did some customisation.
I used the metal frame from the standard panel airfilter and the metal mesh from the ac delco unit.
I araldited the metal mesh into the frame and used three pieces of non-articulated foam from clark rubber.
And a piece of bent plastic coated coat hanger to retain the assembly.
I also use low weight machine oil between the 1st and second layers.
Basically no flow restriction, easy to clean and no chance of pulling through the system.
My Ride:
'94 VR V6 BT1. 15" roh with 225's, stocky with bellmouth removed, OTRCAI, homemade airfilter, B&M Stage1 shiftkit, .490 boost valve. Corvette servo.
Lappy runnin EFILive in a semi stock interior.
WANTED: VN/VP/VR/VS Standard
Memcals.
WANTED: Standard front bar from VR/VS. Prefer alaskan white but will take anything.
Newcastle/Maitland/Central Coast.
Email me
hyp3r4l3rt@hiptop.com.au
Here some pictures of my engine bay and CAI with the homemade filter. Enjoy!
