Results 1 to 4 of 4
Thread: fuse keeps blowing
    vl commodore
    Oct 2008
    newcastle
    Default fuse keeps blowing
    i have a toyota lexan and yesterday one of my fuses blew we took a fuse out of another spot and put it in and we got it home, so we replaced all the fuses, we went to go out this morning did about 20 mins of driving and it blew again, now every time we put another fuse in it, you only have to click it to the reds and it will blow, allowing the car not even to start!!!!! what a good year this is going to be!!!!... and sujestions?????
    coasty's Avatar
    coasty is offline the voices told me to
    vz equipe & vt berlina both v6
    Feb 2008
    kanwal nsw
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Click it to the reds?
    Is the fuse the correct rating? What fuse is it that keeps blowing?
    Failing that
    Sounds like your best bet would be an auto electrician. You've got a short somewhere, fuses blow for a reason.
    Call an auto electrician or get it towed to one.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Description sounds like the fuel pump fuse which will blow if the pump is worn and the pump motor 'poles' or the oil pressure switch shorts internally also blowing the fuse - fault is initially intermittent but gets worse with time. Oil pressure switch is part of the fuel pump circuit.
  1. Blowing fuse VS V6
    By TrustNo1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2008, 04:48 PM
  2. My car keeps blowing fuse
    By bellasmummy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2008, 06:24 PM
  3. vn hazzard fuse keeps blowing
    By whatawookie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 01:12 PM
  4. A/C blowing fuse VP
    By twasm6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2006, 07:29 PM
  5. main fuse keeps blowing up
    By vnv690 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 11:11 PM
