Results 1 to 5 of 5
Thread: help pls
    vs v6 acclaim mod
    Jan 2009
    Default help pls
    vs v6,have pro cleaned injectors & throttle body, changed both oxy sens, had chip checked, changed plugs, leads, coil o k,diagnostic pro tested, cant find problem,,,,,car go's hard but on idle runs rough,, blows & spits black smoke,tail pipe black, nearly stalls, fuel eccon good since all above work done.. plenty of work done to motor and box 18 mths ago no probs till about 6-8 weeks ago,could earth wire b prob???????????? help pls
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    check/clean the IAC valve on the throttle body and/or clean the throttle body...otherwise not to sure but im sure someone else on here may have some ideas
    also give teh car a error code check
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    and check for vaccume leaks around the throttle body and intake pipes....
    vs v6 acclaim mod
    Jan 2009
    sorry checked iac valve ok, no vac leaks, no manifold leaks, thanks 4 replys,have read that chassis & body earth could fix prob,anyone heard about this///
    slipstream001 is offline -=Slipstream=-
    VR Senator II
    Jan 2007
    Werribee, Victoria
    maybe get it compression tested, and also get your timing checked if its out could cause it to idle rough. not too sure about the electrical causing a rough idle. just a thought as my mates GTS developed a "lame" cylinder and it had somewhat the same symptoms could also be your injectors sometimes its something so small yet we think its something major lol, maybe some wynns spitfire to clean your injectors
