Results 1 to 6 of 6
Thread: Vs v6 running rough after replacing battery
    VS V8 UTE
    Mar 2008
    Default Vs v6 running rough after replacing battery
    Replaced battery in my 99 vs ute and now its running rough as, wat could it be, i was thinking a fault code with the computer ??
    VR Statesman
    Sep 2006
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    I know an auto electrician who says this is a pretty common problem with vs's. When you install a new battery or even when you reconnect the battery if its been disconnected for a while, after starting the car up hold it on about 2500 rpm for 30 seconds and this apperently will avoid it developing any faults or running rough. This is obviously less than ideal to do on a cold motor though.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    the tps would need to be reset.... just go for a drive it will sort it self out
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    The computer is a self learning one and is reset when you disconect the battery for more than 20 secs, so when you install the battery it has to relearn some things doing the steps like holding at a rev range for a certain amount of time helps also take it for a quick run on the highway / freeway for 10k`s helps to, it eventually sorts itself out.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    check the error codes mate.
    Last time i disconnected my battery, when i reconected it I had a blown coil and fault code 47.
  1. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  2. vl running rough
    By scozzman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-05-2006, 12:42 PM
  3. VR ute running rough
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 11:56 PM
  4. Running Rough
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2005, 11:47 PM
  5. Running Rough
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2005, 11:48 AM
