Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: replacing the radiator, need help quick!!
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Exclamation replacing the radiator, need help quick!! - trans cooler issues!
    hi there, as some of you may have read, im replacing my buggerd radiator, me and the missus took it out tonight and noticed that the commodore was fitted with a tow kit, and the auxillary trans radiator
    how do i take this off the radiator and how do i install it onto the new radiator?
    is it diy able or do i have to take it to a holden dealership/mechanic
    also, any one got pix/diagram of were the hoses go?
    here are some pix
    [ATTACH][ATTACH][ATTACH]Attachment 57214[/ATTACH][/ATTACH][/ATTACH]
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    un bolt it and pull the bolts through the radiator. its mounted with long bolts through the vanes. hope fully the nuts haven't been rusted on.
    the line can go other way, from trans to radiator through radiator and in to cooler through cooler back to trans.
    has this car got a/c? because its a weird spot to have a trans cooler. most Ive seen including mine has it up the front on 2 brackets to get the cold fresh air first through the condenser than radiator.
    edit: sorry i have no idea what is holding that on i would just leave it off or buy a new unit and mount it up front
    Nov 2008
    rotorua, NZ
    is it easy to mount a new unit?
    how hard wuld it be to remove??
    yea my car has ac, there is another radiator still in the car, this one is connected to 2 hard lines running back through the engine, is that tha ac radiator??
    you power it down!
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by moff_man View Post
    if i do manage to get the bolts out, how do i get them through the new radiator, do i just push them through??
    you power it down!
    moff_man's Avatar
    Nov 2008
    thats the trans cooler attached to the radator the a/c condensor is still in the car.
    verry easy to mount a new unit depending what type you get.
    i wouldnt reuse that unit personaly but its your choice its just ment for extra cooling for the auto trans for towing etc.
    i would be putting the new radator in and worrying about a trans cooler another time, the new radator shuld come with a cooler as per the stock setup anyways, just hook that up and go from there, and remember to top up the transmission fluid too as the new unit will be empty 1/2 - 1 litre should do it...
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by PSYKO PHOENIX View Post
    yeah but be carfull not to damage the pipes and vanes
    Nov 2008
    rotorua, NZ
    all the new radiator came with was the radiator, no trans cooler (for the outside)
    how ever im guessing your talking about the internal one, which it does have. are you saying i can run it on that fine, untill i get the new trans cooler??
    if i cant find a new trans cooler would you suggest using that (old) one any way, just for the extra cooling??
    you power it down!
    Nov 2008
    rotorua, NZ
    theres a few damaged ones directly arround one of the bolts on the trans cooler, is that anything to be worrid about??
    you power it down!
    moff_man's Avatar
    Nov 2008
    it can be, it can rub through the pipe and cause a leak, and being where it is mounted you possibly wont see it till it has leaked a far bit
    Nov 2008
    rotorua, NZ
    will a bottle of radiator stop leak fix the problem?? in other words just to make sure that tere is no leaks??
    you power it down!
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    If it was my car i'd be trying to mount it exactly how it was. That extra cooler gives your trans fluid more surface area so helps it cool better... It looks like quite a big one too, bigger than the average one you see mounted in front of the radiator. Most important thing is do you do much towing , and do you tow anything big like a fibreglass boat or big caravan ? If not you can get away without that extra cooler, and just mount one in front like normal, which will save you poking holes in your new core. New cooler's don't cost much , I read another thread on here recently about this topic and someone said they got a new one for $60. Just make sure the fittings are the same size as yours.
    moff_man's Avatar
    Nov 2008
    not in the trans cooler, and i wouldnt be using it in the radator unless it is nessesery to get you home....
    if you are replacing the radator i would leave the trans cooler off because the new radator will have one anyways, and if you want a trans cooler again i would get a new one and not use the long bolts to hold it on. you can get trans coolers from anywere ranging from 100 bucks to 500 bucks depending on size and brand etc
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by greenacc View Post
    sounds good!
    do you think repco or super cheap would sellthem?
    i think ill try stay with my current one (cuz of its size)
    any i work in radio so while im not expecting to have to tow, i could have to tow at short notice , bbq's stage equipment etc
    you power it down!
    greenacc's Avatar
    VE Berlina
    Jul 2008
    yeah they should definitely sell them. give holden a call too and compare the price ... and search for that other thread that will help you.
  15. #15
    Nov 2008
    rotorua, NZ
    great success!!
    ive got the trans cooler off, it dosent look like its badly damaged at all!!
    im just trying to fina a mounting kit (those 4 plastic bolts) repco are looking for a set for me, any other places that would be able to sell me the bolts etc???
    also im gunna upgrage the trans hoses whats the best kind to get??
    you power it down!
  16. #16
    VR Caprice
    Dec 2005
    It is easy to make some brackets for the trans cooler. ormally you have 2 about 2" pieces of steel and you mount them so the trans cooler sits about 2" or so in the front of the radiator. will try and do some pics when I get home if you want.
  17. #17
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by NeilB View Post
    that would be wicked!!
    so your saying i dont need to mount the trans cooler on the radiator??
    you power it down!
  18. #18
    VR Caprice
    Dec 2005
    No, You just make the brackets so they go in front of the Radiator and bolt/screw them onto the radiator support bracket.
  19. #19
    VR Caprice
    Dec 2005
    they look a bit ordinary but these are my prototype. I did the same at the bottom of the radiator
    Attached Thumbnails Attached Thumbnails replacing the radiator, need help quick!!-101_0080.jpg   replacing the radiator, need help quick!!-101_0082.jpg
  20. #20
    Nov 2008
    rotorua, NZ
    all sorted, i just got a set of those conecter things from repco, and its all on the radiator
    guestion is now, were do the hoses go, any help would be much apreciatedAttachment 57288
    Attachment 57289
    Attachment 57290
    Attachment 57291
    Attachment 57292
    you power it down!
  21. #21
    greenacc's Avatar
    VE Berlina
    Jul 2008
    fluid flows in the bottom hose and out the top hose so you dont have a waterfall in your cooler and get air in the fluid.
    The top hose (out) from the trans goes to the bottom of the cooler , top hose from cooler goes to bottom of radiator cooler, and the top hose from the rad goes back to the bottom hose from the trans. Not sure if it matters if it goes through the cooler in your radiator, or the extra cooler first ... so just run it like it used to be.
  22. #22
    Nov 2008
    rotorua, NZ
    so it goes from the trans to the cooler then through to the radiator then back to the trans?
    you power it down!
  23. #23
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    good to see your well on your way. when plumbing in the external cooler plumb it in after the internal cooler before going back to the trans. the reason for this is that the trans normally runs at about 180 degrees F (thats what the temp gauge shows on the missus VS before the fluid goes into the cooler when cruising). the radiator temps can get hotter then that so it could actually heat the fluid worst case scenario if cold fluid was coming from the external cooler first which we don't want.
    that cooler looks bigger then the factory external cooler fitted by holden. thats a good thing. even with the factory external cooler fitted i've seen temps in excess of 230-240degrees F when stuck in traffic for long peroids of time or under continues high load going up hill from piha beach stuck behind slow traffic (lack of air flow) on a 30 odd degree day. bigger is better
    dude, get the trans serviced, the fluid looks crap, well past it's use-by date. old fluid looses it's ability to transfer heat properly as well as it's lubricating properties. old fluid will help kill the trans faster.....
    Body by Holden, Soul by Brock
    the Legend will live forever
  24. #24
    Nov 2008
    rotorua, NZ
    Quote Originally Posted by immortality View Post
    sweet as bro, will do!!!! i know i guy who services them hopfully hel do it for cheap!!
    as for the plumbing of the radiator and cooler it sounds like it should go like this (PLEASE TELL ME IF IM WRONG)
    bottom line from trans (metal) to bottom conecter on radiator
    top connecter on radiator to bottom conecter of cooler
    top conecter of cooler back to top pipe to trans (metal)
    [/SIZE]
    is this correct?
    this is the part i need to varify before i go any further, once iv got this rightt it should only take 20 mins to do the rest (minus the radiator blead, ill make sure that its more than bled lol)
    please let me know, im gettin differnt storys from all over the place and im just plain confuzed how there sposed to go
    is the order above correct or not, if its wrong what is the correct way??
    thank you all for your help and patient's (i hope i spelt that right)
    im sure ive p!ssed some of you off with my ignorance and for that i am sorry
    im still learning my way arround cars
    thanks again
    you power it down!
  25. #25
    Nov 2008
    rotorua, NZ
    this is what im talking about
    in a hurry, what goes were
    can any one give me a difinative answer, the way the hoses should go (in a form like i just did in red) and what way the trans fluid should flow through the trans cooler (eg top to bottom or bottom to top)
    as you can imagine, im very confused by this and wanna make sure its how it should be before putting it back in - i cant afford to do this again any time soon
    thanks again guys, i dont mean to put anybody down i just need to confirm which is the correct order etc so that i dont damage the trans
    cheers and thanks
    you power it down!
  1. Quick questions about repairs + replacing some parts
    By burnsy150 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-11-2008, 11:40 AM
  2. Quick electrical problem - requires quick answer
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2008, 08:29 PM
  3. Replacing Radiator VS 1996
    By fourboys in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2007, 09:43 PM
  4. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
  5. Overheating since replacing new radiator
    By lovemyholden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2005, 09:16 PM
