Results 1 to 10 of 10
Thread: water pump replacement
    vs ss commodore pantha mica
    Jan 2008
    bacchus marsh vic
    Question water pump replacement
    hi i have a weaping water to, to replace is it as simple as pulling off the belt and then unscrewing the bolts undo and replace with new one and gasket?? should i buy one from holden whats the price or wil one off ebay do?? cheers
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Get one from your local parts store like repco or bursons.
    Not a hard job really, get the old one off, clean up the surfaces, put some gasket goo on either side of the paper gasket and replace and torque up the bolts to required Nm
    Jan 2008
    bacchus marsh vic
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    yeah its easy, just remember to loosen the bolts on your power steering pulley before you remove the belt cos that pulley has to come off to get the pump off. Still easy tho. GMB pumps are ok, made in japan should be stamped on the pump. also remember to add cooling system pellets when you refill the system
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    just remove the fan assy to give your self extra room only 4-5 bolts and a plug
    Jan 2008
    bacchus marsh vic
    greenacc's Avatar
    VE Berlina
    Jul 2008
    they dissolve into the coolant and lubricate the water pump seal around the shaft. Helps your pump last longer so you won't need to do it again in 6 months. They cost about $10 from holden
    Jan 2008
    bacchus marsh vic
    so just put these pallets in at radiator cap im guessing?? when refilling
    greenacc's Avatar
    VE Berlina
    Jul 2008
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Theres a how to for this
    Reaper
  1. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  2. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  3. Water pump replacement
    By Brumbies 5L in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2007, 12:28 PM
  4. Water Pump replacement
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2005, 10:12 PM
  5. Vl Water Pump Replacement
    By PCJ in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-05-2004, 10:53 PM
