Results 1 to 6 of 6
Thread: vs auto problem
    vs
    Jan 2009
    Cool vs auto problem
    hi i think i brock my auto
    i hooked up a 6 metre boat and towed it about 20km only problem was i didnt notice i was in eco not power i was notacing the gear changes where longer than norm
    car drives fine if you drive normalbut push the throtle down and the engine reves high then whack your back a gear while this can be a lot of fun it dose get annoying knowing it wasnt like that till i towed a boat but im not shore or cant remember if at that time i also changed or toped up the tranny oil maybe i put wrong grade oil in like dex i not dex 3
    question is would towing in eco do damage or would it be more like wrong oil /burnt oil
    would changing the oil /filter/pan gasket help? :how do i do code checking
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    dextron 1 is no longer avable and Dex 3 is the new Dex 1 and 2 if that makes sense.
    sounds like the auto was having a hard time but when i borrowed the olds vs to tow a statesman on a trailer it did the same, pull the trailer off and back to normal.
    these autos take load and throttle pos etc from the engine so if its under high load i.e. towing it will modify gear changes etc in the auto.
    the power function only helps with towing bye holding the gears longer and firming up band's etc...
    go for a drive with no trailer and see how it behaves, also check fluid level and have a smell of the oil, if it smells bad change it with a new filter Dex 3 should be used.
    oil companies are releasing Dex 4 5 6 soon as the 6 speed boxes use Dex 6 its the same oil but with different charastics, as long as its a Dex designated brand it should be fine
    vs
    Jan 2009
    Cool
    ok so all the dex oils the same but only getting better
    yeh i had a look at the oil its not red its brown
    the problem i had towing was when i unhooked the trailer i noticed gear box problem
    im thinking the oil was bad before i towed
    auto place tells me that these boxes are pricy to repair and that i should look for good secondhand lol
    yeh !! right ??
    id be buying the same thing
    think im going to drop the box get rid of all the oil buy filter and gasket as it seems fine to drive just when you kick it back a gear it reves up then drops in
    i meen like floor the thing
    THINKING is there a way to drain all the oil without pulling box out
    would save my nabourhood from lots of f#$@ this and gee wizz that
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can pump quite a bit out by disconnecting one of the cooler hoses and run the engine till it stops pumping. You'll still need to drop the pan as well so you can replace the filter. You could also throw in a tin of "new transmission in a can" - this stuff can sometimes improve things and delay the inevitable.
    If you really want all the old oil out just do 2 changes but it's a waste of a lot of oil.
    Vs ex pursuit
    Jan 2010
    Perth wa
    it sounds like uve got the same problem as mine.
    mine is only noticeable when u go round a corner.....the engine idles as u got round then u foot ur foot down and theres like half a second where its almost not in gear?similar to when the tranny fluid is real low?
    no one can tell me what this is.....ive been too 3 different places and they all said the internals on the gearbox were fine
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by 1SIKBT1 View Post
    Yours sounds like the fuel return line in the fuel tank is dislodged - this causes fuel to surge away from the pump pickup when going around a corner and you get either a hesitation or engine dies.....most pronounced when tank is under 1/4. Did you get fuel pump replaced lately?
  1. Auto OD Problem
    By rosevs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 12:30 PM
  2. vp auto problem
    By markovr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2007, 10:58 AM
  3. vs auto problem
    By Nathan72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2007, 08:08 PM
  4. problem with auto
    By KingCoMMoDore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 08:34 PM
  5. problem with VR V6 auto
    By krizko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2005, 09:25 PM
