Results 1 to 6 of 6
Thread: VS Auto trans problem
    VS Vacationer
    Dec 2008
    Default VS Auto trans problem
    Gidday all,
    I've got an issue with my auto transmission in my VS. I think it is dead and will need to be replaced, but...
    It only gives me 1st and 3rd gear, no reverse. I'm thinking maybe something is seriously wrong with 1st gear as it makes a horrible grinding noise, rather than anything else being kaput.
    The box let go driving down the hume highway just north of the picton road turn off, and i drove it in third for about 15 km until i stopped at wilton. It runs fine in third gear, smooth and good, but the grinding noise and slippage (kind of like when the clutch is slipping in a manual) in first gear makes me think that may be the problem.
    Is losing 2nd, 4th and reverse 'limp home mode'? or have i lost the box?
    Cheers!
    P
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    sounds like the box is gorn...
    but check the level first ideling in park and see if there is any fluid in there, top up if nessesery and go for another drive if it was low.
    but im thinking the box is screwed
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The trans has a broken sun gear - the only fix is a new sun gear etc ($850 min) or a full reco ($1700-2000). The parts to fix are cheap but its the labour costs are what make it expensive. This is a very common problem with Commodore 4L60E transmissions.
    VS Vacationer
    Dec 2008
    pretty dear to get her fixed, i'm up for a new case as well... 1100 bucks should get me back on the road.
    transmission bloke said he spent all of last week doing the same job in a number of commodores, a spline thingo breaking off a large bucket shaped steel thing.
    anyway... got it sorted
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Think its actually the 'sun shell' that breaks - its part of the epicyclic gears - they replace it with an aftermarket one which is much stronger.
    iRiot's Avatar
    iRiot is offline Donating Member
    1993 S2 V6 VP Berlina
    Jan 2006
    Red Cliffs
    mine only gives me 2nd and 3rd i went to a auto specialest and i have to get a pressure manifold valve replace so got get it checked its only going to cost me $130
    1994 Holden VR Acclaim Ecotec V6
    1992 Holden VP Berlina S2 retro fitted with VS Acclaim Interior
  1. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  2. VS Auto Trans Problem
    By Megawhats in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2006, 07:57 PM
  3. Vt v6 auto trans problem
    By bordi1983 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2006, 08:44 PM
  4. Auto trans filter change problem
    By hako in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-08-2005, 10:48 PM
  5. VX auto trans problem
    By VXSC6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2005, 09:01 PM
