Results 1 to 10 of 10
Thread: wtf... just went to get trailor......
    VR Berlina N/A V6 3.8
    Feb 2006
    Default wtf... just went to get trailor......
    just connected a trailor on back of commy vr II after spending 2k+ on replacement engine and 2 auto boxes... had done nearly 5000k since replacing motor and trans, just done a oil change. everything running fine until i connected a car transporter on and headed to collected car and not even 20k up road car didnt make any noises or lights on dash it just died.. then wouldn't start... nice guy towed car on trailor back to my place.. then i put battery on charge for 24hrs then refitted battery to car... and blow me backwards bloody engine wont turn over so out came my powerbar and sokect and i couldn't even turn by hand... what would have happened.. there was a light rattle when first started but disappers in under 2 secs.... am i looking a a complete rebuild of engine or is there sum obvisous problems ie timing chain or cam like mentioned in the ecotec seized forum.... any help would be great as i have removed the heads and have poured oil into cylinders to soak down
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    yea mate most likely seized if that engine was sitting aroud for a while cuz the oil pickups get crap in them and block up
    Eureka styles!
    Feb 2006
    ohh ok just tought id find out so just check all galleries and possibly acid bath to clean engine out k so the rattle i take would be the oil pump?
    Jan 2008
    qld
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Feb 2006
    cheers guys ill continue stripping block.. suppose wait till timing chain off then try turning crank independant from cam and vice versa... mite as well put sum go fast bits in at same time lol....
    Feb 2006
    on that note what parts would be good to chuck in while i have i stripped besides new rings and bearings... thought bout the 4.1 stroker kit and possibly a head shave
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    You could, or you could just leave all that, and fix it up and just get it going. Its just a 6 if ya want it to go just whack a turbo on it.
    Reaper
    Feb 2006
    Feb 2006
    hey can anyone tell me what the part number for the full engine gasket kit is as our parts guy at work is f'n usless i have looked it up on the acl website
  1. WTB: ASAP Trailor (VIC)
    By xlr8_87 in forum Swap / Wanted to Buy / Trade
    Last Post: 07-02-2007, 03:50 PM
