Results 1 to 17 of 17
Thread: water usage
    1997 Commodore VS11 Esteem Sedan
    Dec 2008
    Default water usage
    using plenty of water, no bubbles in radiator or frothy oil what could it be????,Doesn't go over half way temperture wise. Vs Esteem series 2 1997
    None
    Aug 2005
    Adelaide, SA
    VZ SV6
    Oct 2008
    Newcastle NSW
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Usual culprit is the waterpump - check under the pulley for a dried coolant trail - usually you will not see the coolant as it evaporates almost instantly as its very hot but it will leave a whiteish deposit.
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    usually its the waterpump or heater tap, but as the posts above suggest, it could be hoses, radiator, radiator cap, possibly heater core, could also be a leaking welsh-plug..
    have a look around your engine, check over all the hoses.. and let us know what you find.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I have the same issue in my VS esteem. The reservoir will drop to half way in about a month.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Try bleeding it properly and then only filling it up via the tank, not the radiator. The VS is notorious for air locks. The air expands and pushes too much coolant into the reservoir then out the overflow, once it cools it sucks the coolant back into the radiator.
    Visit my Facebook page
    VRII Acclaim
    Jul 2005
    My VR is emptying the reservoir in a week. I was going to start with the inlet manifold gasket? Water pump is less than a year old, never see any coolant on the ground. Got me a bit stumped.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by kopper69 View Post
    You'll only ever see coolant on the ground if its a massive leak and/or it also leaks when the coolant is cold. Normally the coolant will leak most when it's hot....and the hotter it is the quicker it evaporates...basically instant - plus it usually leaks onto a very hot surface like the engine block which keeps it at around boiling point so you never get the chance to see the actual coolant leaking.
    An old trick is to draw a chalk line around the radiator cap, the waterpump or any other probable leakage points. When it leaks it will leave a smudge/stain in the chalk line. They used that on Merlin V12 engines in WW2.
    HSV VT GTS
    Dec 2008
    i just had my heater taps changed today cos i was losing water too. the only reason i knew where it was coming from is because the system needed a MASSIVE flush out and it left a brown mark and trail in the engine bay where the water was coming out and where it drained. got the whole system pressure tested and new coolant and thermo checked too, well worth it.
    the thing with cooling systems is if you replace a part with a new one, it will put more pressure on the weakest part of the system and eventually that will fail.
    Bite off more than you can chew, then chew like hell - Peter Brock
    pando666 is offline milk comes in 2 litres
    vs exec
    Jul 2008
    sydney
    yep my heater tap was leaking loosing about 1 to 2 litres a week, because its so close to exhaust manifold I never saw any water. while looking for leak I was tightening hose clamps and the heater valve broke, replaced valve no more problem.
    faroogoo's Avatar
    faroogoo is offline SENTINEL
    GMH
    Nov 2006
    S.A
    Also check the end tanks of the Radiator especially mounting points,if theres a hairline crack it will leak out when driving but will be minimal when parked.
  15. #15
    VS l67 statesman
    Dec 2008
    Had a leak in a vp once ,it turned out to be the heater core it would only leak under pressure while hot , I found out one day when I was driving and the pressure got too much and the thing let out an almigthy hiss coolant ,steam and expletives every where it still shits me thinking about it and the 9 hours to fix it pulling the dash out , but if I were you I would start by bleeding the system My Vs stato would empty the overflow tank in a day before it was bled
  16. #16
    vs wagon
    Jan 2009
    Unhappy water loss ?
    i just had same prob, and it was cooling core for g/box which is housed inside your radiator, hence water in g/box, and vice versa, worth checking.
  17. #17
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Cassandra69: how did u end up goin? did u find the cause yet?
    being a first post, n a week now, may not hear back
  1. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  2. Oil Usage
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2007, 11:56 PM
  3. Usage?
    By Wicked_D in forum General
    Last Post: 25-03-2007, 07:38 AM
  4. How much oil usage is too much??
    By Krustyone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-06-2006, 04:20 PM
  5. Oil usage?
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2005, 07:42 PM
