Results 1 to 10 of 10
Thread: 06/95 vs bt1
    vs bt1
    Jan 2009
    Melb, VIC
    Default 06/95 vs bt1
    Hey guys,
    just wondering what the differance between the standard vs and the vs bt1's were?
    ie: motor, trans, diff etc etc.
    cheers, Ben.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    exacly the same nothing special just screw holes in the dash where thay had there crap mounted.....
    1994 VR Exec, 5.0L BT1
    Jan 2005
    few things different, but nothing to increase power.
    From an exec base model the police pack includes: FE2 suspension, LSD, IRS, SS interior (for 5.0L models), 2km increments on speedo, extra light above speedo (you should see the hole in the top of the cluster), when plant the foot the auto trans drops to 2nd without moving the stick, and some have a kill switch for the interior dome light.
    I think that's it.
    weedo_86's Avatar
    weedo_86 is offline JC Resident FireFighter
    03 VYII Clubby M6, 92 Barina With Sunroof :)
    Feb 2006
    Melb, Vic
    have a search dude its been done about 4500 times already
    DVLHSV Stage 2 is Now in Operation
    My VYII Clubsport http://forums.justcommodores.com.au/...clubsport.html
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    The VR's also have airbag. i think that came out standard in VS? also have larger fuel tank,sump and tank protectors, might be the same in VR/VS but the VX-VZ had different brake pads (grey ones) which are higher tensile(i think thats the word) but they chew discs and you'd hope that they have been changed since 1996 lol also had no brake shield on the knuckles not sure thats a benefit or not. They also had a magical chip that makes 400KW at the wheels :P
    vs bt1
    Jan 2009
    Melb, VIC
    thanks guys,
    spddmn - mine's a v6, im not to sure if i have a lsd.. but i noticed the first time i drove it, you plant it and yeh drops to 2nd and takes off. its good lol.
    hmm interroir killswitch...... i'm having problems with my interrior light atm.
    cheers, Ben.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by lo-rolla View Post
    cheers, Ben.
    If it's staying on it could be due to the dome light switch turned to the "on" position - it's located on the headlight switch.
    vs bt1
    Jan 2009
    Melb, VIC
    hako - what happened was when my mate still owned the car it blew a dash light unit fuse, so no speedo or gauges etc. he went to pull the old fuse out but grabbed the wrong one (drunk of course) he pulled out the interrior light fuse. he realised it was the wrong one and put it back in and ever since then light has stayed on.
    A mate tested it with a multi-meter and came to that it was the little button on the door jam. swapped it over with another one (out of my old vn) and still nothing...
    Jan 2005
    Quote Originally Posted by xcopv-8 View Post
    forgot about them details
    The kill switch (if fitted) is too keep the dome light off, not on. So I'd say you have a different problem. That's another one, bt1 had calais dome lamp with the map lights.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I still reckon that you should check the "stay on" switch.....most people don't even know it's there and every Commodore Exec built has one.
