Results 1 to 12 of 12
Thread: power windows
    System's Avatar
    System is offline Control is a way of life
    2005 VZ commodore exec
    Oct 2007
    Default power windows
    hey all, i have a 93 acclaim VR sedan, and i've been having trouble with my passenger and left rear power windows. Sometimes they work, other times they dont move at all, u just keep clicking the up button untill they finally go. I have a feeling its the motors, right now the rear one just WONT budge, its all the way down, which got me thinking- is it just dust in the window railing stopping it from moving? Has anyone else had this problem?
    Unions: the people who brought you weekends
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Could be the front switch. One block controls the left side windows and your having troubles with the left side. See if that is your problem.
    System's Avatar
    Oct 2007
    yeah was thinking that- got the back one up, found out i had the window lock button down hahaha :P
    but, ye that window only goes up with the door switch, not the centre consol one- so i'm guessing theres some wireing loose somewhere, checked this morning, it all looked intact. My main worry is the front passenger window, its drivin me nuts now, takes for ever to get it up, you sometimes have the button down all day then finally, it starts up and closes. cant hear the motor wining away to get through any gunk thats in the frame- so i'm guessin the motor is on its way out?
    VR Equipe II
    Mar 2008
    QLD
    same thing happens to my passenger window
    1 minute it will work next nothing
    it went like 3 -4 weeks without doing it
    then the other nite did it again i need to know this aswell
    ****ing me right off
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    Spoke to a guy yesterday, and he said Check your switches first, before you go buying the regulator from a wreckers etc.. Hopefully its just your switches, the regulator wasnt fun to fix today when i did mine.
    dont worry, il start a ride thread soon.
    VS l67 statesman
    Dec 2008
    Usually it your switches ,swap them over from left to rigth to check them ,sometimes the little tabs break on the bottom of them and you can glue them ,and other times a electric window will play up because the BCM on its way out ,I have had both promblems in my VP Berlina in the past ( and yes it will only affect one window)
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    the bcm is only in use for the drivers window auto down..
    i'd disassemble the switches and check and the metal contacts, its easier and can be done quickly. possibly swap switch blocks with a mate and see if the problem follows.. then if the problem is still there, look at the reg. remove the door skin and disconnect the wires from the reg, with a booster battery, keep winding up and down the window to see if the motor is on its way out.. u can check the movement of the window on the rubbers also..
    should point you in the right direction.
    System's Avatar
    Oct 2007
    i've seen u can get power window silicon spray to lube up the gap in the door frame- maybe a clean up in the track might loosen it up abit, but, i'll try all that out as well, cheers for the help
    1994 VR Exec, 5.0L BT1
    Jan 2005
    One of my windows wasn't going down from the front switch. I pulled the switch apart to try and fix it, ended up with parts everywhere fixed the switch but broke the childlock feature. I'd wager it's the switch more then nething.
    Get a test light and hold it to the wire going the the button ur pushing, if the switch is working the light will come on when you press the switch. That's how I determined for sure it was the switch
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by System View Post
    or graphite powder, i've used it in the past and it works a treat
    Quote Originally Posted by spd_dmn View Post
    one of the most simple testing methods that i had totally forgot. very wise suggestion.
    rep points on there way
    virgin commo is offline OZ Rocks
    97 vs 5spd wagon
    Nov 2008
    Default intermintent electric widow
    Have a VR Berlina ... found the problem when i lifted the switch from the switch body ... be careful ... under the switch is a little plate on its edge that the rocking switch pushes ... this can fallout easily as you pull it apart ... clean it and swap it end for end ... it will get better contact and help solve your problem
    VZ Calais
    Aug 2005
    Mackay Qld
    Just curious.......when the window fails......are the lights on the switch block working?
    The easiest 'fix' i have found for pwr windows, is to do as above^ with the test light, but find 2 terminals & short them out, while holding the switch in.
    The VN-VS are a little more difficult, but a small screwdriver or unshielded test light do the trick.
    VK-VL are easier, just use a 20c piece. LOL
    That little trick has earned me beer! LOL
    Cheers, Col.
    P/S. If you figure out the motor is faulty, shoot me a PM.
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  2. power windows and c/c a/c
    By iRiot in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2008, 10:57 PM
  3. Power windows, off then on !
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2005, 09:43 PM
  4. Power Windows
    By 96VS in forum General
    Last Post: 31-10-2005, 09:27 PM
  5. power windows
    By Stretchomatic in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2005, 09:32 PM
