Hey guys,
Read through most of the Air con stuff but couldn't find this exact problem. My air con works fine, but the fan works about 50% of the time. With no fan I can't get the cold air to blow. My mechanic said it could be the fan unit itself which means the whole dash has to come out. I'm hoping it may be something simpler. Fuses etc seem ok. Any ideas? I've been driving round with the fan "on" all the time now and it seems to work at random - I drove for 30 minutes and it didn't work at all. Next drive it started straight away and ran the aircon for 2 hours straight....
Old Colts in Oz - Saving Old Colts but not the 80's spec FWD kind. See www.oldcolts.com.au for details.
What mine was doing might be the same but mine has climate control.
It would be blowing on my face all nice and cold and suddenly would stop blowing, turned out to be the vacuum solenoid which is situated below the radio behind the console fascia.
Replaced it and all is perfect now.
Check out this thread might help.
http://forums.justcommodores.com.au/...tml#post980819
cheers SW
HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
Check the resistor pack:
VN-VS Fan Speed Resistor Removal
Pretty sure you don't need to pull the whole dash to remove the fan motor (they rarely faily BTW)
Thanks guys. It's a 95 basic VS ( no ABS, Airbags etc ) so it doesn't have climate control. I'm kinda hoping there is a dodgey wire/switch or something causing the problem.
Could be a tricky one. I would try hako's suggestion of replacing the fan speed resistor. Even if it doesnt fix the problem it will prevent other problems in the future. That one will set you back $50.
I would get a multimeter, get some alligator probes on the end. Connect to the fan (just need to remove the glove compartment and a plastic panel or two). You will then measure the voltage on the fan. Drive around, when the fan is turned on but not working, check the multimeter voltage reading. If there is power there, but the fan isnt on, you know it will be the fan. If there is no power the fan isnt to blame.
Actually check relays too. Relay might just be a bit sticky. Swap the relay called the 'ignition relay'. It has nothing to do with the ignition, but the interior fan.
Also try giving the dash a bit of a hit when the fan isnt working and see if that fixes the problem.
So the crazy heat in Adelaide finally took it's toll and I got this checked out by an Auto Electrician. Turns out it was an $18 Relay - $53 all up with labour. Stoked. Only problem now is, as soon as I left the place my car starting running rough - backfiring on petrol and LPG and breaking down when I put my foot down. I took it back and they said the Relay was nothing to do with the car running bad - just coincidence. It makes sense but I can't beleive the bad timing. I drove the car 50km this morning with a Trailer on the back and it ran fine. A similar thing happened a while back and it was a Coil pack. Anyone know if the VT coil packs are the same as VS? My brother has some spare VT packs.
Thanks
Its most likely resistors or wiring...
VS Berlina 1995 3800V6 W.A
