Results 1 to 6 of 6
Thread: anybody know what the temp gauge incremints
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Lightbulb anybody know what the temp gauge incremints are??
    not sure if i spelt any of that properly but
    2 questions -
    1) how accurate is the stock water temp gauge on the stock VS cluster?
    2) does any one know the increcements and high and low temp numbers??
    eg. lowest temp is 40 degrees, increcements of 5, high 120 degrees
    i was thinkin about popin the cluster out and putting the numbers on it, so i can be a cheap bastard and not buy a water temp gauge lol
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    yeah its-
    C-Really bloody cold
    1/4 - Standard Operating Temp
    1/2 - A ****ing hot arse day
    3/4 - You havent taken good care of your coolant system now have you?
    H - Nuclear Fusion
    aZk.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    1/2 is approx 100 c 1/4 is about 80 c 3/4 your fans ant working or radator is blocked
    03 VY Supercharged 3.8L
    Stack The Cats Champion!
    Nov 2008
    Tullamarine, Vic
    Yea, the guages are accurate (well, normally anyways). Temperatures are roughly what the other guys have said
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    One must remember that the VS has a very indicative gauge, some more so than others, so it's probably best taken as a rough guide. Half is normal running temp on a hot day, but most of the time it should sit around 1/3 or thereabouts. Going up to 3/4 is perfectly normal too, indicating that nothing is wrong with the system, but at this point the cooling fans should come on. From memory the lowest point C on the gauge is around 60 deg C, and the highest point I would imagine would be around 130 deg C. The cooling fan comes on at the low speed at 104 deg C, but that can be anywhere from just over half way to 3/4 on some cars. High speed fan is 109 deg C if not more, but the gauge may not show this.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    normal is around 95c which is the quarter mark.
    low speed fan comes on at half 100c.
    high speed fan comes on at 3/4 110c.
    any more than 3/4 you have something wrong.
  1. Where does your V8 temp gauge sit
    By V8 Berlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2009, 04:16 PM
  2. temp gauge
    By SLO 057 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2008, 03:11 PM
  3. Car Temp Gauge
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-09-2008, 10:57 PM
  4. Temp Gauge
    By Mr_Calais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2006, 07:26 PM
  5. Temp Gauge !!!!?
    By Turbo_dreams in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-06-2006, 01:14 AM
