Results 1 to 5 of 5
Thread: This is drivin me crazy
    VS V8 Commodore
    Mar 2006
    Angry This is drivin me crazy
    Car- VS V8 Commodore BT-1
    Car cut out after 5 min s driving, waited 5 mins , started again, ran fine
    1 month later, car stopped and could not start again for 24 hours, then ran fine all the way home, 35 mins
    Went to mechanic they said electrical
    Got mobile electrical guy out and as the car was fine he could not find fault, he made me up a globe and a couple of wires so I could check the ignition module when it happened again
    It happened again, 5 mins from home, did the test as suggested by electrician, got an ignition module from wreckers and it made no difference, returned ignition module to wreckers, car started 24 hours later
    Took car to mechanic , checked and cleaned fuel pump and fuel filter.
    Replaced coil.
    He suspects distributor, so I got a new distributor,, has not been installed yet.
    Over Christmas I tried to start it and it would not go.
    There appeared to be a light flashing under the dash and a ticking.
    Next time I tried to charge it , the battery was dead, I put a trickle charger on it overnight and it did no good. No power at all, not even dash lights.
    I tried to jump start it with no success
    Next day I tried to open the car to take the battery to get charged up and I could not unlock the car, either by button or manually with the kay
    Q. Could this problem be related to the key/immobilizer
    Q. Could it be computer/chip
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    When you charged the battery overnight but had no dash lights , did you check to see if the battery was charged by using a multimeter or a test light? If the battery is OK then i would be checking the wiring from the battery to earth and starter. Also check the wiring to the alternator and the fuses for any bad connections from corrosion.
    pursuit_special is offline Legal Expert
    VS 1996 Series 1
    Jan 2009
    Perth, Western Australia
    My mate had the same problem, spent thousands on all sorts of possible things. The Sharp owner of my local autoelectrician ended up fixing it for about 60 bucks. It turned out to be a faulty immobilizer, he just bypassed it and that completely fixed the problem.
    My mate had a BT1 V6 VS, we put the faulty immobilizer down to the fact that some BT1 electrics caused problems with it.
    I really hope this helps.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    VS l67 statesman
    Dec 2008
    Hi my vp used to do the same thing ,it was the immobiliser playing up ,so I used turn it off while driving ,but you cant do it with the vr-vs they dont have the key in the passenger door
  1. VZ Sv6 ute goes crazy
    By mattieschwarz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-05-2007, 01:11 AM
  2. CRAZY CRAZY ABABS!!! nutters, seriously
    By MikeVXSS in forum The Pub
    Last Post: 02-12-2006, 06:46 PM
  3. crazy bus
    By hakhawk in forum The Pub
    Last Post: 23-05-2005, 12:00 AM
  4. Drink Drivin'
    By Darren in forum Jokes/Humour
    Last Post: 05-06-2003, 12:04 PM
