Results 1 to 6 of 6
Thread: Sway bar upgrades
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Sway bar upgrades
    Having done lowered suspension and shocks, I'm thinking of upgrading the sway bars front and rear, aswell as the links.
    Can anyone point me towards some info on what sizes of sway bar have what specific affects on handling of a sedan?
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Go the Whiteline adjustable bars then you can set the car up how you like.
    They sell direct to the public over the internet.
    https://www.whiteline.com.au/store/
    SW
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Dec 2008
    Thanks, but im more after information than a supplier at this stage. For example what handling characteristic will a bigger sway bar in the front give, What about if i upgrade the rear but not the front, how big, etc?
    VR2 Exec
    Jun 2005
    Antiroll bars obviously affect the stiffness of the suspension in roll and supplement the stiffness given by the springs, the balance of the roll stiffness front and rear has a major bearing on the cornering characteristic. A stiffer front bar will cause the front end to LOSE grip. The bar increases the amount of weight transferred across the front tyres compared to the rear, and because the traction capacity of a pair of tyres decreases as the weight transfer between them increases (governing laws of the tyre), that end loses grip.
    However, if you increase the front and rear bar stiffness in proportion, the vehicle should slightly gain grip overall, due to the centre of gravity not moving to the outside as far during cornering loads (weight of car not tipping onto the outside as much), but it is really only marginal... For the track, you basically want to set the car up so the suspension roll angles are equal front and rear, therefore neutral handling... From the factory the front roll bar is probably too stiff, or the rear too soft... For incompetent 'drivers', understeer is safer and feels more natural than oversteer.
    Oversteer scares passengers, understeer scares drivers!
    Dec 2008
    VS V6 Acclaim
    Jul 2008
    Whiteline adjustables are for the hardcore.
    For a balanced cost effective upgrade to your sway bars, replace the front and rear link kits. You may find that is enough and will also give you a feel for how it has influenced the handling.
    I am using complete Noltec, however, all the bush manufacturers have them at reasonable prices.
  1. VT Sway Bar
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2008, 06:20 PM
  2. FE2 Sway Bars
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2007, 12:08 AM
  3. sway bar...
    By nmj in forum General Discussion
    Last Post: 02-05-2006, 05:25 PM
  4. Best Sway Bar
    By death-from-above in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 05:53 PM
  5. VN sway bar link kit??
    By stockVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2005, 03:04 PM
