Results 1 to 9 of 9
Thread: help vr stalls sometimes
    vrII wagon
    Dec 2008
    vic
    Question help vr stalls sometimes
    ok vr on gas works most of the time but occasionally it stalls about 10 seconds after starting wch ****es me off because im already down the street after stalling it takes few seconds to start and sometimes stalls again but yet other times it runs fine dad said the injectors might be clogged but i think hes just guessing i ran some injector cleaner through it but no change anny ideas i got nothing
    VS V6 Acclaim
    Jul 2008
    If the problem is lpg only, it may be your paper filters in the LPG supply line.
    You can leave them out for a test and see if they are the culprit, then source fresh ones if it is resolves.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    My limited knowledge of LPG installations tells me that the injectors have nothing to do with LPG gas supply...the injectors are for when running on petrol and you have a "mixer" or something similar for the LPG.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    vrII wagon
    Dec 2008
    vic
    no it does the same thing for both somtimes its fine and occasionally it stalls or doesnt start in fact today i left it at work because it wouldent start at all to go home
    VRII Acclaim
    Jul 2005
    Try checking error codes. Instructions can be found in the how-to section. May get us a starting point.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    greenacc's Avatar
    VE Berlina
    Jul 2008
    could be the ignition module if its not the CAS. Make yourself a pin or paperclip and keep it in the consol. whenever you have a prob check error codes straight away, its always a good place to start
    vrII wagon
    Dec 2008
    vic
    it was the crank angle sensor all fixed now
  1. stalls on gas sometimes?
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-02-2007, 06:06 PM
  2. Help car stalls
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2006, 08:37 AM
  3. stalls when hot
    By radiohead in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-08-2006, 10:40 AM
  4. stalls
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-07-2006, 08:29 PM
  5. Vp V8 Stalls
    By finarfin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2003, 10:30 PM
Tags for this Thread
