Results 1 to 10 of 10
Thread: VT brake upgrade
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    Default VT brake upgrade
    I found a cheap (well cheapish) VT brake upgrade for my VS, and i know there have been questions about them before, but I just want to know for certain - Is there anything illegal or unsafe about using the shims that come with the kits?
    I have no problems with the extra work involved with installing VT brakes over slotted VS/good pads, but I just want to make sure it is 100% safe and legal
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Just done mine on my V8, sloppy pedal due to ABS, so a standard set up would help a bit, there are shimless rotors around now so have a hunt, as for legal well it`s an upgrade to a safer stopping power so if its done correctly then legal it should be.
    Jun 2005
    legally it needs an engineers certificate, but havent heard of anyone getting done for it. this link will come in handy
    VT booster and master cylinder into a VN
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Philthy's Avatar
    Aug 2005
    I was under the impression that in the VS the master cylinder wouldn't need replacing? Or is that just people saying that you can get away without upgrading it, but it is really best to.
    I want to do this properly the first time, so should I put in a VT booster and cylinder as well?
    EDIT: If it does need a booster/master cylinder as well maybe I will just go with standard calipers and slotted rotors with good pads. I had these on my old VS and it stopped well, and felt good in the pedal
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Using the VS master is fine but if your pedal height is still a bit low for your liking then you can fit a VT master if you use a spacer between the master and booster.
    Racebrakes in Sydney sell them.
    I use the VS master and spacer rings with my VX HSV 330mm fronts, brakes are great.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    yeah, the master is optional, but there have been several threads where people have said their VS master carked it soon after doing the VT upgrade due to longer pedal travel from the larger callipers. Its easy to add a VT master later if you need to.
    Philthy's Avatar
    Aug 2005
    Hmm...pedal feel is a major factor for me. I'll just get the kit and start looking out for a master cylinder, then if it feels soft as shit I'll just whack that on
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I have the spacer rings on my brakes > No problems with them!
    I installed the complete front VT brakes/ rotors, VT master cyl and booster. All quite easy to do mate.
    These are the trickiest parts that you will come across:
    - unbolt the booster mounting bracket (off the rear of the VS booster) and redrill holes to fit it to the VT booster
    - Take the reservoir cup off the VS master and fit it to the VT master (redrill the locking bolt hole)
    - Redrill the VT booster pushrod hole distance so that it matches up to the same height as the pushrod on the VS booster.
    You will love the braking performance! good luck
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    Jun 2005
    so i just need to redrill holes, not make a new bracket? will this be the same as a VR booster?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Quote Originally Posted by stocky View Post
    Vr booster needs more mods than that stocky. Its the same mods as the link you posted above, not a big job at all if you have the right size holesaw
    I have also had my certified by an engineer and rubber stamped by the rta. You have to, otherwise you basically void your insurance as it gives them a loop hole to not pay you.
    But maybe buying a VS bracket might be the go by the sounds of it.
    Vt booster m/c in Vr V8 with ABS
    Reaper
  1. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  2. vn-vt brake upgrade
    By hutto in forum General
    Last Post: 04-12-2006, 11:18 PM
  3. vp brake upgrade
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-11-2006, 05:55 AM
  4. Brake Upgrade
    By wise_grasshopper10 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-09-2005, 01:14 PM
  5. VN to VS V8 Brake Upgrade
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 01:46 PM
