Results 1 to 11 of 11
Thread: vr v6 gasket
    vr 3.6
    Jan 2009
    Default vr v6 gasket
    ive got a vr v6 and yesterday i checked the oil and it was milky and 2day i pulled the top of the motor and the gasket is suffed can it be the head gasket to wats suffed as well witch is lettin water mix with the oil
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    you said you pulled the top off the motor (i'm guessing you removed the plenum) and the gasket was stuffed. that right?? there's more chance of it being the valley gasket rather than a head gasket. yes a dead manifold (valley) gasket will allow a water/oil mix
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    vr 3.6
    Jan 2009
    i pulled the motor the bits and replaced or the gaskets and its fine now but its doesnt idol right it reves high then drops back down lower and keeps doing that
    VR EXEC
    Dec 2005
    quarantine
    sounds like an air leak. double check all your vac lines are back on
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    check vac lines and gaskets around the throttle body.
    Reaper
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    check the map sensor hose hasnt been disconnected as i accidentally disconnected it when i did the inlet gaskets on me sisters VP and it did the same.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    check for air leaks, sometimes like what i did, i accidentally turned the screw on the throttle body and that throws out the base idle.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    you pulled the injectors out yeah? did you replace the O rings? you should have.
    Jul 2006
    o-rings dont always have to be replaced, check if brittle etc, cause you can have small probs later trying to fit the injectors back in. For some itsan easy process, some like myself, i had bought the new o-rings, but saw that the originals were quite good. I took them out connected to the fuel rail. What you must do however is use VASELINE on them to get them back in, so they go in easily, otherwise you can get fuel leak.
    VRII Acclaim
    Jul 2005
    Just on o-rings and other injector parts -does anyone know where these can be purchased? I asked at holden once and was shown the available parts. They did very little other than the complete injector. If anyone knows a supplier for fuel injector parts or the size of the o-rings i would be interested to hear.
    vr 3.6
    Jan 2009
    problem sovled it was a hose at the back wat came off
  1. gasket tip
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2010, 09:37 PM
  2. Is my Head Gasket Gone????? Please HELP
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2006, 10:45 AM
  3. blown gasket?
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 04:30 PM
  4. WTB: Mr Gasket bug catcher
    By Nos_VQ in forum Swap / Wanted to Buy / Trade
    Last Post: 09-04-2006, 09:21 PM
  5. VRS Gasket Set?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2006, 08:02 PM
