Results 1 to 11 of 11
Thread: wat wrecked car do i need
    vs calais
    Jan 2009
    Default wat wrecked car do i need
    hey all!
    i wanna do an egine conversion to my vs calais and people say its cheaper to buy a wrecked vehicle to get all parts. now do i need to get a vs or can i get any model that is injected (im converting from the v6 to the aussie 5L)? are all the computer components the same? and as i read on a thread else where it said when converting from a six to an 8 you gotta change the fuel tank and fuel pump? is that right, i mean i can under stand the pump side of things but not the tank surely? cheers for the help pple!
    VS Commodore Omega
    Apr 2005
    I would get a whole wreck because at the very least you're going to want the better brakes, V8 is a heavier engine which will mean you'll need the extra stopping power, possibly stronger suspension but I'm not sure on that.
    The V8s I think have a larger capacity fuel tank.
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Its not the capacity thats wrong I`m sure its the set up most sixes have a low pressure in tank pump and high pressure external pump the V8`s have a high pressure in tank set up (or the other way round).
    The only capacity difference is the station wagon 68ltrs, and lthe long range option 80ltrs (avalible for all models) sedan V6 and V8 is 63ltrs
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Your best bet would be to make a list of all the parts you need - offhand I can think of ECU, Radiator, transmission and maybe fuel tank for the pump difference. Brakes are the same. Add them all up and its probably cheaper to buy them individually than get a whole wreck (also some of the wrecks parts will be wrecked)
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Depends where your from, i know here in nsw the engine must be newer than the car, which limits you to VS and VT S1. But check with a local engineer near you. I do know a guy who put a VP 8 in his VR and he still got it passed because supposably its a bit hard for the engineer to tell which model the engine was from as they are all the same. But you dont nessacarily need to buy a wreck. If you can find an 8 in a car thats in poor condition and can get it cheap, you can do a swap of the engines and sell the six off again.
    Reaper
    VS 355 Turbo, VN Calais 5L, VE SII SV6 Wag, Mirage
    Aug 2006
    Adelaide, SA
    The fuel pumps in the 6 and 8 in VS range are the same as are the brakes the same from v6 to v8 in the vs range. if you're gonna buy a wreck you'll need to buy a VS wreck as you will need to run a vs ecu and engine harness.. VN-VP-VR-VT S1 are all different to the VS loom.
    If you buy the parts individually it will add up cost wise... and u will find it hard to find a VS v8 loom and ecu as they are pretty rare.
    u will need
    engine with all accesories
    loom, ecu, ignition module
    gearbox crossmember
    engine k frame
    v8 headers or extractors
    gearbox with all accesories and tailshaft
    v8 radiator and hoses. + heater hoses
    clutch fan and shroud
    and a few other small bits
    as u can see a wreck is clearly the easiest option.
    Aug 2006
    Adelaide, SA
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by PREDATR View Post
    ???Whats so special about the VS as opposed to the VN/R ones. They were all the same VN/S last i heard. Just thought the VS S3 and VT S1 had a few more bits on them to make them the only different ones
    Reaper
    Aug 2006
    Adelaide, SA
    VS S3 and VT S1 had sequential injection, PRE VS S3 had batch fire injection. VN-VP-VR had kickdown cable for auto trans, VS had electronic trans.
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    u will need
    gearbox crossmember
    engine k frame
    I'm doing the VN V8 & 5sp into a HZ, so i don't need all these parts, but i got a whole car for less than the motors are going for.
    Aug 2006
    Adelaide, SA
    exactly wrecks are cheaper wreckers charge the earth for parts!
  1. Pictures of a wrecked VE..?
    By Troy711 in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-02-2009, 03:36 PM
  2. Wrecked police car
    By danja in forum The Pub
    Last Post: 10-11-2008, 02:49 PM
  3. wrecked vs
    By VryNeat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2008, 06:18 PM
  4. my wrecked vx 2
    By VY ACCLAIM WAGZ in forum VT - VX - VU - WH - V2
    Last Post: 16-04-2007, 10:53 PM
  5. Wrecked VN Calais
    By VNV6VENGEANCE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 10:01 PM
