Results 1 to 3 of 3
Thread: engine oil in powersteering ???
    vx berlina
    Aug 2005
    gladstone
    Exclamation engine oil in powersteering ???
    hi guys i have a 97 vs v6 auto and the other day i was out and about when i suffered a bad powersteering leak the only fluid i had in the boot was engine oil i had no choice so i filled the powersteering up with it there was still about 1 cm of powersteering fluid left in the bottom of the resovoir when i added the engine oil; it seems to drive fine maybe just a little heavier when u turn corners im just wondering if it will cause any dramas cheers muzza
    VR Executive 95
    Jan 2009
    South East - Edi
    Hey dude,
    Just let it drain out and re fill it back up with power steering fluid should be fine! But if that doesnt work see ure mechanic as he will drain the power steering fluid and re fill it! Also do you know how i can take out the original stereo head unit in a vs??
    cheers
    vx berlina
    Aug 2005
    gladstone
    hey m8 cheers for advice as for the stereo i had my replaced by autobahn for 80 bucks and i watched him do it u have to pull off all the dash surround to get to the wiring behind the stereo not a hard job just need to look at the dash undo sum little plastic screws and have sum patience hope this helps
  1. powersteering pump
    By anfsvl in forum Parts And Other Items For Sale
    Last Post: 16-04-2006, 01:24 AM
  2. powersteering
    By ultimate_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-04-2006, 11:00 AM
  3. no powersteering turning right.
    By saville in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-12-2005, 03:06 PM
  4. powersteering problem
    By play in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2005, 04:17 PM
  5. VH powersteering
    By PinkVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-07-2004, 11:11 AM
