Results 1 to 3 of 3
Thread: VR PROBLEM QUESTIONS - plz help
    VR Executive 95
    Jan 2009
    South East - Edi
    Default VR PROBLEM QUESTIONS - plz help
    Hey Guys,
    1st Question
    When i drive my car it is at 500rpm its an auto VR now is this normal to rev at idle at 500rpm? Just curious wat is the normal idleing RPM for a VR as i mite have to fix it. Also when im driving and brake it sounds like the engine is gonna die on me or has stalled when it gets to 500rpm is this normal?
    2nd Question
    How do i take out the original stereo head unit and replace it with a brand new one? what is the process?
    CHeers guys
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    We'll continue using this thread as this one has more info in it, u can post more info in a thread by hitting the 'edit' button
    Q1: i believe the normal idle rpm is ~700, for the stalling, i would start with a quick throttle removal and clean, removing the sensors and cleaning them with carby cleaner. refit and see how she goes.
    Others will have more ideas but thats all i can think of atm.
    Q2: i believe there is a 'how-to' on this in the how to section of the forum. check thru that, and/or do a quick search, there was just another thread about this that i checked before with a quick run down in this very section.
    EDIT: Kovacic_VR95 its your other thread Urgent question on a installing a head unit and a reply was posted just before 10am this morning, remember to check your previous posted threads before posting another thread, and edit them if you have more info to add
    VR Executive 95
    Jan 2009
    South East - Edi
    Cheers mate ill check about the RPM
    also ye soz new to this computer ***d up meh... will do one thread next time
  1. Vn Questions And some other Q's
    By ThisNameIsTaken in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2010, 09:19 PM
  2. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  3. few questions
    By reggie_c2005 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2007, 05:33 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. intermittent problem with starting and also other questions
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2005, 03:22 PM
