Results 1 to 8 of 8
Thread: VS needs help
    '96 VS Series 1
    Jan 2009
    Default VS needs help
    Have a '96 VS Series 1 Commodore, showing error codes 46 & 47, have changed ECU. Car starts travels about 10 klms and stops, shuts down, can take between 2 minutes and 2 hours before it will restart. Any ideas how to fix this problem? Thanks.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by gail52 View Post
    Sounds like the all too common CAS problem. Next time it stalls pour some cold water onto the cas, if it starts replace the CAS.
    MY RIDE
    '96 VS Series 1
    Jan 2009
    Razedaze is offline Razedaze
    VS Berlina
    Jan 2009
    Banks Peninsula, New Zealand
    Default Vs stops when hot?
    I have a '96 VS that did the same thing, have sat on the side of the road many times wondering why. Then I removed the thermostat from the engine, it has not stopped since. Good luck.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd reckon accenstencil is on the money with his post - crank angle sensor. My opinion only but I wouldn't bother messing around - replace it before you get stranded in a vulnerable location - like the middle of a 3 lane roundabout. Should cost less than $200 fitted and much cheaper if you do it yourself.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    hako and accentstencil are on the ball just do it mate.
    VS Wagon Engine Just Cuts Out
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Yep, classic symptoms of the crank angle sensor failing. I'd replace it asap, I had mine done in the Berlina a few years back at Holden, cost about $150 including the part, plus it came with 12 months warranty. Just out of interest, how many km has your car done?
    If the new CAS doesn't solve the problem, it will be the DFI module (the thing the coil packs sit on), the CAS and DFI are very closely related, and sometimes produce the same error code.
    Vs V6 ute
    Jan 2009
    i've had that problem before Gail52, but it turned out my fuel pump was cutting in and out... pi$$ed me right off... replaced the pump and everything was fine. so maybe check that too. (i didn't have codes coming up on the self-diagnostic tho.)
