Results 1 to 10 of 10
Thread: ##weird petrol smell in car??
    vr executive
    Nov 2008
    Default ##weird petrol smell in car??
    i gota vr series 2 exec and everytime i open the door to drive it it smells like petrol/fumes. once i start driving it goes away if i have the windows open but if i floor it the smell comes in the car again. i have checked the petrol tank for leaks and it doesnt have any... what could this be and how do i fix it?
    thnxx jordan
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i think your carbon canister in the engine bay thats either leaking or needs replacing.
    have you checked for any fuel leaks in the hoses or lines?
    VH Commodre
    Jan 2009
    hey i got the same problem but i think mine is coming from the gasket between the motor n the headers cause wen i accelerate it sounds like air is escaping like a putting sound to the engine but wen i sit on say 60kph the sounds disappears till i put my foot back down. also leaves a vapour stain of sum sort around that area.
    wouldnt have a clue im a newbie anyway.
    VS V6 Acclaim
    Jul 2008
    Yeh, check the engine bay for sure.
    You may have knocked one off the press fit lines off of the vapour cannister or have cracks, loose clamps somewhere.
    Make sure you deal with this ASAP as you have a fire hazard there.
    vr executive
    Nov 2008
    where exactly is the carbon cannister and what does it look like?
    \cheers
    VH Commodre
    Jan 2009
    yeh wer is the carbon cannister <newbie> to commodores since 1 week ago i started lookin at the engine
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    should be next to the battery, looks like a big black cylinder with 2-3 little hoses coming from it.
    VH Commodre
    Jan 2009
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    i have found a few commodores with a few km's on them to have leaking fuel caps, once the car has been driven for a bit get out and smell all around the car, if you smell fuel around the cap replace it.
    the last one i did had this same issue and it was a vg commodore ute....
    VRII Acclaim
    Jul 2005
    There are breather hoses around the tank that will normally cause the fuel smell when the tank is full. Inside the cabin fuel smell normally comes from the engine bay. Just have to check everywhere really closely. Give all the hose clamps a tighten. Have a search around the forums to see what other people have done to fix the problem.
  1. petrol smell
    By skyper in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-11-2008, 05:22 PM
  2. petrol smell
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2008, 12:12 AM
  3. petrol smell
    By bboystyles in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 12:07 PM
  4. Petrol smell in car
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2006, 01:19 PM
