Results 1 to 3 of 3
Thread: Help with “Lazy” Cruise Control on VS Calais V8
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Default Help with “Lazy” Cruise Control on VS Calais V8
    My Calais has been off the road for the last five months getting an engine rebuild. Now that it’s back on the road, I find that the cruise control is very lazy and slow although it still works. The cruise control on/off button seems to work fine and the cruise on lamp comes on/off at the right time. However, when I press the “set” button, the cruise engagement lamp comes on immediately, but the car loses around 10kph over the next 5-10 seconds, after which the speed gradually increases to the set amount or a little bit lower. Same thing happens if “resume” is selected once cruise has been disengaged via the brake pedal. Disengage works fine and is immediate, but taps ups and tap downs are also very slow. I’ve swapped the cruise control module for another one but it didn’t make any difference. Appreciate any ideas and help.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The only other 2 things involved in the system would be the speed sensor and the ECU. You could try swapping the ECU over to see if it makes it better.
    I doubt it would be the switch.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    is the cable tought? it should have a little paly but not too tight this may be causing the slow ingagement as its use to the shorter length
    also is the cable kincked, im not 100% shure on how the v8's run there cruise wire but if its kincked than it will cause it to be slow also
  1. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  2. 90 Vn Calais Cruise Control
    By Dr.304 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2007, 03:20 PM
  3. Calais dash and cruise control
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-01-2007, 01:29 AM
  4. VK Calais cruise control transducer...
    By KBone in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 10:31 PM
  5. vn calais cruise control
    By HaRm in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2004, 07:36 PM
