Results 1 to 6 of 6
Thread: how low is too low?
    vr berlina
    Aug 2008
    Default how low is too low?
    i have a vr berlina which has been lowered on 18s, was that way when i bought it, is pretty dumped as the wheel arch covers the top of the tyre. just wondering if it would still be alright with a full car as well as having a sub in the boot and spare tyre or if it would hit the guards?
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by vpcommo View Post
    Only one way to find out But um not quite sure depends how stiff the springs are and if the guards have been rolled etc i guess.
    Smarter people should pop up
    MITTZ is offline smoke em' up!
    VR executive
    Sep 2008
    adelaide hills
    in my opinion, that low is to low
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    too low is 100mm clearance without a full car including sub well thats the legalities aside
    all depends on the offset of the rims, some done scrub at all with a full car load and others scrub with only 1 passenger in the back. i could rub on the inner guards or outer guards.
    if inner guards, incorrect offset, either raise it, or change rims with the correct offset.
    if outer guards, roll the guards and that should just about do it. or adjust the camber a little bit at the risk of premature tyre wear.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Basically if you car is too low for the suspension to work correctly (ie. if you are bottoming out on the rubber bump stops) then your car is too low. Might look nice but won't handle as well as cars that have not been lowered as much.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    well all depends on what you like your ride to feel like, mine is pretty low and is pretty much hits bumpstops on any small bump but i doesn't worry me
    but some of my mates hate the ride of my car, but meh! my car my choice
