Results 1 to 13 of 13
Thread: Tyres: Wearing inside edge on left back tyre, IRS.
    VS Statesman, VY Holden Equipe
    Jan 2009
    Te Aroha, Waikato
    Default Tyres: Wearing inside edge on left back tyre, IRS.
    Hi, can someone give me a cheap cure to help stop the wearing inside edge of Left Rear Tyre. The Tyre is only 8 months old, is on a VS Statesman IRS. Have replaced tyres & set at 30psi. Front tyres are wearing fine. Is it a common problem? as I Have seen similar wear on an SS? Also whats the cure for brake dragging on front disk,is it is only minor? New brake line or replace rotor, it doesnt make noise or smoke...minor wear on inside edge only...Cheers.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    How cheap is cheap?
    Camber kit is around (maybe less) $200 from what i remember. Other than that, theres not alot you can do. VQ/P- VT series I have a shit IRS design, which is prone to the wearing of the insides.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Jan 2009
    Te Aroha, Waikato
    Yeah thought it was common problem, have bought a near new 17" tyre for $20. Guess i'll stick to cheap tyres.Thanks.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Get a 4 point camber kit, front at rear. Also get a touring tyre or a tyre with a stronger designed edged.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Had a wheel alignment lately ?
    I have a VS acclaim, IRS, and the back tyres wear perfect, 15 inch, get at least 60000k's out of them ,RE92 or the like. 30 PSi is too low , try 35. Brake drag is probably caused by sticky calliper slides or seals. You can either buy a calliper rebuild kit for about $10 a wheel, or just buy a sachet of permatex calliper grease for $2. Clean the old grease off the pins and apply the new stuff , works well.
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Quote Originally Posted by STEALTHY™ View Post
    How cheap is cheap?
    VTII-VYII still seems crap VZ seems alot better, don`t know what holden did different though?
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    Quote Originally Posted by whiteknightVR94 View Post
    dont forget ve lol when will holden learn............also how is the shocks and springs, if it is lowerd than it will allways scrubb out the inside edge of the tyer.
    also all holden irs diffs has no camber adjustment's only had toe adjustment if your luckey enough to have the arms to adjust......
    vs wgn series 2 v6 5sp getrag,vz wgn auto dual/f
    Dec 2007
    nthn suburbs, vic
    Quote Originally Posted by greenacc View Post
    im guessing you dont have fe2 suspension, i was told by a mechanic its mainly the ones with fe2 that wear out unevenly, maybe something to do with being a bit lower is my guess.
    VS Calais S1
    Jul 2006
    Kadina, SA
    Hmmm come to think of it i noticed something similar on my car today, both my rear tyres are due for replacing but when i was pumping em up today i noticed that the left one had more wear on the inside than the right. And thats with 16" rims on stock suspension with IRS.
    VR S Pack - 5 speed
    Sep 2008
    Moorebank
    pretty much the only thing you can do is install a camber kit.. and that isnt a cure.. it does help though.. if its standard height the camber kit should be able to get it almost perfect... if its been lowered then you're always gonna have alot of camber... ive installed a camber kit in mine and its alot better but still pretty bad... i was thinking about pulling out the trailing arms and cutting them and changing the angle and re welding them to suit the height of my car...
    also if your left side is worse than maybe the spring has sagged or your shock is ****ed or your bushes are worn... could be time for some new suspension components... maybe go to a good suspension place and get it checked...
    so anyway from memory camber kit is around $150... you can put it in yourself though you'll need a press to press the old bushes out and the new ones in.. i built a press as im always in need of one when working on cars and shit lol..
    and once its installed if you do it yourself take it to a good suspension place to get a full wheel alignment... and when i say good i mean take it to a place that does it properly with the instruments they fix to the wheels and the monitor that tells them the exact measurements and angles and stuff.. its the only way to do it properly... about $60 for wheel alignment.
    Adam.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Quote Originally Posted by mattyr82 View Post
    Correct, standard springs is what i have. and to stiffen it up i use sports rider shocks. Thinking about lowering it, but don't want to start wearing the tyres. ho hum.
    moff_man's Avatar
    Nov 2008
    ive seen cars with about 1.5deg+ of negitive on the rear and found the control arm bushes to be worn out (inner ones near the diff housing and tail shaft)
    mxmark is offline vs2dy4
    Vs acclaim (ecotech v6)
    Mar 2009
    Wangaratta
    when commodores are lowered with IRS the camber becomes more severe, therefore more tire wear. Camber kit will fix the problem. did for me
  1. Tyres wearing out on the inner side
    By Taddy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-03-2009, 02:36 PM
  2. 17 inch csa edge rims/tyres(adelaide)
    By stateo 304 in forum Parts And Other Items For Sale
    Last Post: 20-05-2008, 11:25 PM
  3. Tyre's Wearing Out On Inside !!!!!!!!!!!!!
    By Joey_21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 03:31 PM
  4. inside rear tyre where
    By xu1au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-05-2006, 07:08 PM
  5. VT Commodore Tyres Wearing Rapidly
    By Jeep in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2005, 10:13 AM
