Results 1 to 10 of 10
Thread: Rotors and Hubs
    Holden VR Commodore
    Jun 2005
    Gold Coast
    Default Rotors and Hubs
    Hey guys,
    Im up for new front rotors and i was wanting to know do i have to replace the wheelbearing hubs when fitting new rotors?
    Nate
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    no, rotors only, they together with hubs. Wheel bearings i think can be regreased on ur model which is worth doing with wheel bearing grease. Easy to take apart. VT, VX for sure is sealed unit, and must replace whole bearing.
    Some performance rotors keep the gold hub or whatever, and you only replace the disc surface area, bolts on.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    No, the VR has a sealed hub as well. You only need to replace the rotors. If you want to go slotted I can do you a good price on RDA rotors, even standard if you don't want to go slotted.
    Visit my Facebook page
    VH Commodre
    Jan 2009
    Didnt want to start a new Thread but has anyone got a good guide on how to change 1994 VR brake pads..
    i have the caliper off and taken the old pads out. inserted some Ztech pads . now the caliper wont fit over the rotor disc , do i need to rebleed them or just get somethin strong to spread them apart so they fit back over the disc.
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by kapzi View Post
    Plenty of workguides for this in the "how to" section, but in brief, use one of the old pads to rest on the piston and use a g-clamp to push the piston back in slowly. Then it will fit back over easily. Pump the pedal a few times to get the pressure back, and check to make sure none spilled out of the reservoir.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You need to push the piston back into the caliper. Refit the old pads into one side and place it back over the rotor so when you push the piston in on the other caliper it doesn't pop that piston out. There are numerous threads on changing brake pads.
    Holden VR Commodore
    Jun 2005
    Gold Coast
    Thanks for the replies guys!!
    I'm glad i don't have to replace the hubs as i was quoted $205 each for the front ones and $102 each for the rear's. To expensive i think!!
    Nate
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by Tekka View Post
    Thats a fairly cheap price... I take it thats for NON ABS hubs, as the ABS ones are well over $350 each for the fronts... been down that track 3 times with my old VS...
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    One of mine needed replacing too, but I sold it as is....it was ABS as well.
    Holden VR Commodore
    Jun 2005
    Gold Coast
    I told the guy over the phone that my VR is a ABS/IRS model and he quoted me those prices. So i guess that is really cheap compared to 350 bucks!!
    Nate
  1. Replies: 20
    Last Post: 15-01-2008, 01:42 PM
  2. VS Hubs the same as VT?
    By nick88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2006, 01:03 PM
  3. VS Hubs
    By DaPlaya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-05-2006, 08:43 AM
  4. painting calipers and rotors/hubs
    By VksupaNoob in forum General
    Last Post: 10-02-2006, 09:05 AM
