just realised its missing, can i just get the top bit and click it on or does the whole module need replacing.
I think you will need to replace the whole module. The bad news is they cost around $130 from GMH. The good news is you should be able to get one off eBay for less than $20. I bought one for $5.50!
replace it with one from a vs.
the newer switch is much more reliable. i have had 4 old ones in my vr. but then upgraded to the vs style and havent looked back
nah mate, just pop off the "banana" shaped cover thing on the door handle
inside there u just unclip the wire connecter thingy
and then push the switch out from the inside of the door handle
cheers, a member on here has one for sale so ill follow that up, too easy
