Results 1 to 8 of 8
Thread: Revs too high
    VS Executive S2
    Jun 2008
    Default Revs too high
    Hi,
    My manual VS revs funny.
    Often when I go to stop at the lights or a stop sign or wherever, I put the clutch in (as you do so you don't stall), but it revs quite highly. It hangs around 2000 for a bit and then drops to normal idling 750 revs after a few seconds.
    What is the problem and can it be fixed easily by me (don't know too much about these things)?
    Cheers,
    (a secondary question: when I accelerate beyond Granny Mode, a breathy/airy sound can be heard, sometimes even whistling. Any ideas?)
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    when about when you put it in neutral and let the clutch out and roll, does it still stay high? Or is only when you have the clutch in?
    VS Executive S2
    Jun 2008
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    I would be cleaning your throttle body and removing the Throttle Position Sensor and Idle Air Control valve and give them a good clean too, then see how it goes. Sounds like the TB is letting in too much air on idle hence the high rpm.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    either gunk round hte throttle, clean as Mack posted, or you have a vacuum leak or hose has come of the pcv valve at the back from the throttlebody
    VX SS T56
    Feb 2006
    my manual vs did this.
    If you were rolling with the clutch in, it reved high, once stationary it settled down after a few seconds.
    I would still clean the TB and the IAC just to be safe.
    VX SS - Twin 2.5 cat back - MAFLESS Tune - MCAI
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    throttle body gunk... my vs 304 did the same thing .
    SIR LS1
    the two ton go kart
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    or it could be what happened to me once, the screws that hold the butterfly in place loosened and jammed the throttle body open as i was approtching a stop sign. its not nice
  1. whistleing under high revs only
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2007, 09:27 PM
  2. revs too high!
    By kwik6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2006, 10:58 AM
  3. vk v8 cuts out high revs???????
    By mitchplz520 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-12-2005, 10:07 AM
  4. REVS. how high?
    By statesman_vs_s1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2005, 10:34 PM
  5. High revs for no reason
    By DJ Majah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-11-2004, 01:12 AM
