Results 1 to 8 of 8
Thread: engine
    vr 3.6
    Jan 2009
    Default engine
    can you put diesel in ur motor and let it idel to clean the crap out of the motor
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    not reccomended but i have heard if people doing it, also it can lead to a run away situation where it will pick up on the reves and only stop when it sezes......i would just buy the cheep oil and change it each week and when its clean put the good stuff in...
    VB SL/E
    Dec 2008
    I've heard you can use diesel oil as it has a higher detergent content but it is not recommended for extended periods cause i think it also has a higher zinc content or something that may wreck the O2 sensor.
    System's Avatar
    System is offline Control is a way of life
    2005 VZ commodore exec
    Oct 2007
    i've been told a LITTLE bit 2 stroke oil mixed in the tank cleans out the injectors
    Unions: the people who brought you weekends
    vr 3.6
    Jan 2009
    can u pore diesel in the motor and just have the sump bolt out and let it run out to clean it out
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It's possible you are talking about putting diesel fuel - not oil, in the sump and running it to loosen crap. Back a few years it was not uncommon to flush the engine by filling the sump with kerosene and idling for a minute or so and then dumping the lot. That was when compression ratios were about 6 to 1 whilst nowdays they are around 10 to 1 plus engine clearances were much greater than in modern cars.
    So really there is no way I'd put diesel fuel in the sump. Diesel oil is OK in an engine that is not worn but as VR38 says it may affect sensors.
    VB SL/E
    Dec 2008
    Running your motor with a fuel as the lubricant is asking for a fire or explosion even IMO.
    ImCrAzY is offline Ebay is my one stop shop
    VR's
    Feb 2008
    Have to say I've used the procedure on the last few cars I've bought and havent had an issue . Each car the oil was black as , so dropped the oil , sump plug back in of course , thrown in 4 litres of diesel , kicked it over and let it idle for a few minutes , no revving . Dropped out the diesel and filter , changed to the right stuff , and for the last 2 years every oil change hasn't come anywhere near the colour black . No blown seals or sensors .
    Not recommending anyone doing it , just saying that it does clean it out good and proper though
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  3. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
