Results 1 to 17 of 17
Thread: what causes tailshaft to hit the body?
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default what causes tailshaft to hit the body?
    hey guys.
    i was replacing my fuel filter this morning and had a look at my diff.
    just above where the tailshaft joins the diff with the 4 bolts.
    there are a few scrapes on the body of the car.
    only thing i could think of is
    1. i had too much weight in the car and it was too low so it hit.
    2. one of the uni joins etc is broken in my tailshaft.
    thanks again for all the help you guys have given me
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    could possible be the spaces on the centre bearing mount are in the wrong spot, leaving your tailshaft out of alignment. any other scraps along the body where the tailshaft runs?
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    grab a straight edge and just verify that the tailshaft is straight, although you would feel a rumble throughout the car if hte tailshaft was bent
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    ahh i dont think the tail shaft is bent.
    its probably because i split it in two when i done the manual conversion
    and i forgot how it goes back together.
    i really need to get some pictures on where abouts it goes. then it should be all sweet.
    because im pretty sure its out of allignment
    VT
    Apr 2005
    QLD
    None of what you're saying makes sense.
    Trust me, you would know if one of your uni's were broken.
    There are physical stops that would prevent the tailshaft hitting the floorpan if your car was 'loaded up', providing you haven't removed the rubber bump stops.
    If you have had the tailshaft unbolted off of the yoke, then you could have cause these marks without realising it.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    ahhh the joys of liveaxle lowering yes its probably because your to low/to much weight in a low car...
    same thing happened to me :P... all i did was tap that section a bit with a hammer and painted over it..... last time i checked it was fine (i know, a little dodgy) lol
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    is the uni joint in line of the scrap mark? the nuckle thats bolted to the diff flange.
    unless you hit a major major bump and bottomed out causing hte tailshaft to hit the body. looks fairly recent too.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    yep same thing..... see that little rubber thing thats on the bracket above the diff?
    that bumpstop is probably worn which is what is letting it hit the floor... you could do what i done, abit didgy to be honest but it worked
    (dont smack the shit out of it lol, big hammer with small taps)
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    hmm it doesnt really bother me i was just wondering what caused it
    cause i reckon my tailshaft is out of whack
    VP Executive R-spec
    Jan 2005
    It happens alot with manual Toranas, enough to wear holes in the floor, The diff twists up under power and grinds on the floor. I haven't seen it happen on a Commodore before though
    3.8 VS exec
    Feb 2005
    same thing happened with mine except alot worse, but i guess thats what you get with ultra lows and 4 people in the back. i just raised the back end up a lil bit, also panhard rod seemed to have helped with that and other scraping issues..
    1996 VS Caprice V8. 1996 Proton satria.
    Jul 2008
    Seaford, Victoria.
    i have my exec sitting on bump stops, and i've noticed when i floor it, it hits the body, and does exactly what happend to haydes car. it doesn't do it now, because its gouged a rut in the floor pan, just like haydes.
    nothings wrong with you're tailshaft mate =]
    The all new TATA Nano, India's $3000 low cost car, Runs on Chicken Vindaloo!
  15. #15
    Swordsy's Avatar
    Swordsy is offline mmmm beer....
    VUII Maloo R8 - XJR1200 - XR450R
    Nov 2007
    Newi NSW
    Is that all?!?!?!?! :P
    Too low and too weight, mailny happed for me with 5 people in the car
  16. #16
    SLO 057's Avatar
    SLO 057 is offline i got chevy badges LOL!
    VX BERLINA 5.7 A4
    Mar 2005
    S.A HAPPY VALLEY
    my vn calais i owned befor defected and striped riped a hole in the floor, due to ultra lows in the back and trying to tow the bosses trailer! wasnt happy! but that nothing to really worry about
    VS UTE SOLD
    NEW RIDE VX BERLINA 5.7
  17. #17
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    hayden i'd check the rubber's ontop of the diff, they will do this if shot.
    when you launch thie car the diff turn's it's nose up plus lowerd mean's scrapies
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  1. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  2. V8 tailshaft
    By yaf_ool in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-09-2005, 11:16 PM
  3. is vn v8 tailshaft same as v6
    By vncala in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-09-2005, 11:49 PM
  4. tailshaft v6 to v8
    Last Post: 05-07-2005, 07:49 PM
  5. Tailshaft
    By AirStrike in forum General
    Last Post: 01-05-2004, 04:31 PM
