Results 1 to 7 of 7
Thread: Rough idle, Rough take off and rough stop.
    1996 VS Caprice V8. 1996 Proton satria.
    Jul 2008
    Seaford, Victoria.
    Default Rough idle, Rough take off and rough stop.
    Ello.
    Lately i've notices a bit of a rough idle.
    When the engines cold, it's fine, but after a drive, it gets worse.
    Basically what happens is, i'll pull up to traffic lights and just before i stop, i feel a bit of a surge in the engine, i think when it kicks down to 1st is when this happens - not sure.
    Then, when i take off, a split second after i put my foot on the gas, it'l surge again, only for a split second and then it's fine.
    And also when i put it in drive or reverse.
    It started happening about a week after i changed the tranny oil and filter. about 2 months ago i did a full service, oil, spark, filter and general clean up.
    I'm stumped as to what it could be, i did a search but no one's symptems are the same as mine.
    Cheers, Matt.
    The all new TATA Nano, India's $3000 low cost car, Runs on Chicken Vindaloo!
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    have a look at the throttle bodey, under it there should be a hose sorta on a 90deg bend that goes under the intake manifold runners down the back of the motor. see if the vaccume line had come off, its not uncommon for this line to come out of the 90 deg joiner.
    also you should hear louid sucking noise whan running this is not normal. and indicates the line has come off
    alloywelder is offline blue series 111 vs ute355
    vs series111 ute
    Jan 2009
    Default rough idle
    you have a vacum leak at inlet manifold check all vacum hoses if you are sure they are all attached properly by a can of aerostart and spray around inlet manifod where it meets cyl heads if idle smooths out youve found problem also check brake booster vacum line (this is my bet going by info you have supplied) good luck
    Jul 2008
    Seaford, Victoria.
    Yep, it was the vac line, must have knocked it out when i took out my amp power cable.
    Cheers!
    VS Executive S2/ VT SS
    Oct 2008
    S/E Suburbs
    Hmm sounds exactly like mine, did it idle fine when it was in park/neutral etc?
    Time to google where the Vac line is and check it i think :P
    Oct 2008
    S/E Suburbs
    Wouldn't happen to have a pic of where the VAC line is would ya mate so i can check out mine? can't seem to find any for a VS on google
    moff_man's Avatar
    Nov 2008
    directly under the throttle body, it goes under the inlet manifold to a switch block at the rear of the engine
    Quote Originally Posted by Adam Savage (mythbusters)
    I reject your reality, and substitute my own.
  1. Rough Idle VR
    By audiosoup in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2011, 10:55 PM
  2. Rough Idle With A/C on
    By DzRBenson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2008, 09:25 PM
  3. rough idle.
    By lord_davros in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-11-2005, 02:40 AM
  4. Rough Idle!!!
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2005, 01:43 PM
  5. vn rough idle
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2004, 08:34 PM
