Results 1 to 4 of 4
Thread: foglight switch installation question
    VY SS
    Jun 2006
    Albany
    Default foglight switch installation question
    okay i bought a factory vs foglight switch off ebay and i need some tips on how to install it. first question is can that piece of plastic that covers the hole be removed in anyway or will i just have to cut or file it out? second question once i have a hole there will the switch just pop in or is there another piece of plastic thet needs to be screwed in behind it so it can clip in as i can remember seing a screw hole behind it when i removed the dash a while back.
    any help would be great cheers.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    You will need to cut out the section. I used a dremel with a cut-off wheel. It made light work of the job. I then filed down the edges. To keep the switch in place you will need a plastic bracket which is attached by two screws to backside of the fascia. The part number is 92044316 and cost $1.82 from Motor Traders. The screws cost $0.77 each (part number 92138131). Have fun.
    VY SS
    Jun 2006
    Albany
    well i cut the hole and im just makin a bracket thing out of plastic which will hopefully work haha i should be alright otherwise ill try my luck with the wreckers
    VY SS
    Jun 2006
    Albany
    well its all fitted and working fine now, looks a bit dodge from the back but you wont see that bit lol thanx for the reply anyways seraphic06
  1. fog light switch installation
    By vt com in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2007, 01:44 PM
  2. traction control switch installation
    By jarrod587 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-02-2007, 07:26 PM
  3. VY - Foglight Switch
    By holdensupporter2005 in forum Electrical Wiring / Questions
    Last Post: 26-02-2006, 05:52 PM
  4. Vu (vx) Foglight Switch
    By budgie47 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2005, 06:15 PM
  5. Vu (vx) Foglight Switch
    By budgie47 in forum Electrical Wiring / Questions
    Last Post: 14-09-2005, 06:14 PM
