Results 1 to 10 of 10
Thread: Replacing V6 water pump
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Question Replacing V6 water pump
    Two questions...
    1: I need to replace the water pump and have looked through my Gregory's manual. Looks pretty straight forward. But do I need to use any gasket sealant on the new gasket? There's no mention of it in the Gregory's.
    2: Is it necessary to use loctite (or similar) on the water pump bolts when reassembling? It says so in the manual.
    Cheers.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
    ImCrAzY is offline Ebay is my one stop shop
    VR's
    Feb 2008
    Gasket sealer is a must , as for the loctite , hmm , guess thats optional .
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    id use some sort of sealant on the bolts as im pretty sure the big bolts screw into water gallery's in the block so the sealant is there to stop the coolant from seeping through the threads
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Gregorys doesn't mention using a gasket sealant as its not needed but sealant is needed on the bolts to stop the bolts seizing when coolant seeps into the threads.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    upto you, ive always found doing my cars the few times i didn't use any gasket goo the water pump gasket leaked before the water pump ever died. Since putting a little gasket goo over the gasket it seems to help the gasket seal and last longer. You dont need much as you dont wanna get it in the water, just enough to help seal the gaps so water dont rot the gasket and leak out.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    ive only ever used head stud sealent on the bolts, and the gasket surfaces much be clean and all old gasket surfaces removed so its nice and flat
    Mar 2005
    South Coast, NSW
    I bought the new water pump and some Permatex Blue RTV gasket sealer today. Just wondering if the gasket sealer would be suitable for the bolts instead of the loctite. I just want to make sure I do the job right the first time.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    should be fine mate. I've never had mine come loose... I use permatex No.3 but its all the same.
    Mar 2005
    South Coast, NSW
    Quote Originally Posted by greenacc View Post
    Thanks mate. It's not coming loose that I worried about. It's stopping coolant seeping into the bolt threads that others have mentioned that worries me.
  1. Vs water pump - Electric pump.
    By Lazin in forum V6 Development And Modification
    Last Post: 06-05-2011, 07:08 PM
  2. replacing water pump
    By pom89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-11-2008, 12:49 PM
  3. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  4. Davis Craig Electric water pump 80litre pump
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 16-07-2008, 10:31 PM
  5. replacing water pump.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-03-2007, 09:34 PM
