Results 1 to 10 of 10
Thread: Quick question to VS wagon owner
    VS Executive
    Nov 2008
    Wollongong
    Default Quick question to VS wagon owner
    Hi everyone
    Just had a quick question I couldn't find the answer to with the search button. I have a 95 VS wagon and when I unlock the boot I can't take the key back out.
    Like I'll turn the key to unlock it, then push the button in to open it and then i have to turn the key back to lock to get the key out. Its kinda annoying because I can't leave the boot unlocked and I always have to turn the car off and take the keys out of the ignition to get the boot open.
    Is this normal or is there something up with the lock?
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    I dont know about the key issue, but does the wagon have the button in the glove box to unlock the boot??
    dont worry, il start a ride thread soon.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Mine has central locking so I must admit I have never tried. I will try later today. To answer the second question, the button in glove compartment appears in the sedans only.
    hsvpunk's Avatar
    vy ss II M6
    Jan 2007
    Mornington, Vic
    Quote Originally Posted by seraphic06 View Post
    ahhh, i wasnt aware of that.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    That is normal - the owners handbook says: "the tailgate can be unlocked with the master key. However the key cannot be withdrawn while it is unlocked - you must turn the key back to the upright (lock) position before the key can be withdrawn. This ensures that the tailgate will be locked when all doors are locked"
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    The tailgate on wagons without central locking works as above all the time.
    On wagons with central locking the tail gate can be left in unlock position but if the car is centrally locked and you use the key to open the tail gate without operating the button the key can only be removed in locked position.
    The same applies when using the glove box key if you don't have the electronic key.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    VS Executive
    Nov 2008
    Wollongong
    The thing is I always unlock the car using the central locking and I still have never been able to unlock the boot and take the key out
    Do you think something could be stuck in the lock position? Maybe a wire not getting to the tail gate?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    All VS Commodores have central locking fitted standard (AFAIK) and the previous post of mine was a quote from the official owners handbook which you get when you buy the car new. Your description in your first post (Like I'll turn the key to unlock it, then push the button in to open it and then i have to turn the key back to lock to get the key out) is exactly as it should happen: <you must turn the key back to the upright (lock) position before the key can be withdrawn> A
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    As stated above, you cannot unlock the tail gate and leave it unlocked with the key.
    The central locking actuator may have burnt out and not operating the tail gate.
    If you pull the trim off the tail gate you will find the central locking actuator.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    VS Executive
    Nov 2008
    Wollongong
    I'll take a look at the central locking actuator next time I'm at the car (Which won't be till feb cause i'm currently working in another state)
    Thanks for all the quick replies...
  1. Quick question
    By voney in forum Site Feedback / Site Problems
    Last Post: 27-12-2008, 11:12 PM
  2. a quick question
    By ratz26 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2008, 07:24 AM
  3. New VY 'S' Owner, Detailing Question
    By Flat_White in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-07-2008, 11:28 PM
  4. quick question
    By pgen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2007, 02:52 PM
  5. Quick Question: VT SS RIMS = Quick Answer please
    By Henerz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 06:33 PM
