Results 1 to 4 of 4
Thread: Noisy Air Con Compressor
    VR Calais
    Jan 2009
    Smile Noisy Air Con Compressor
    Hi. I have just had my Air Con Re-Gassed and had some leaks fixed. Also I had a new Filter installed. All was working ok for a day or two and now I am getting a noise somewhere in the Engine when the Compressor is running I cant pin point where the noise is it sounds like it is coming from the Compressor but hard to tell. when the compressor is off the noise is not there. can anyone help or suggest something I can do to see if the Compressor is ok and where is a good place in Brisbane to go.
    thanks Sutto
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    welcome to the forum firstly...
    bit hard to know what to tell you without an idea of what the noise sounds like. grab a bit of garden hose and use it as a stethoscope and see if you can pin-point it.
    Short of that are you able to take it back to the place that re-gassed it for you? they'd surely shed some light on it...
    VR Calais
    Jan 2009
    Hi. Thanks for the advice with the hose I tried it and the Noise seems to be coming from behind the pullys and the Power Steering refile box. The Pully that you use to remove or install your main belt. The noise is hard to explain but I will give it a try. it sounds like a crackling noise like a piece of papaer is being hit by something but there is no paper in there. Holden recently installed a new engine, Radiator and water Pumb. The noise is not as load as it was yesterday.
    Thanks Sutto
    91 VP 5.0 V8
    Nov 2006
    Sydney,nsw
    while your engine is running have a look down at the compressor at the front and see if its spinning or if its locking up,might need a new compressor or be re-adjusted.
  1. noisy fan vr v6
    By slick1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2009, 03:36 PM
  2. Noisy A/C compressor VR
    By vl_davo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2008, 05:40 PM
  3. Noisy 3.8
    By Loupy31 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-04-2008, 12:39 PM
  4. vk compressor
    By unregistered in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-01-2006, 08:30 PM
  5. Noisy Air Con
    By Zedlen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2005, 01:56 AM
