ive got a vr series 1 v6 and i took it for a drive for about 10 mins and it dies and wont start till its cold it happens when it gets hot i try starting it but will not fire until its cold
And?
Error codes? Sounds? Symptoms?
You can't expect an answer from "It won't start".
It is highly likely that your crank angle sensor is a bit dodgy. When they get worn out they generally don't like heat. Try pouring some cold water over the sensor and starting.
This VS is guarded by shotgun 4 nights per week - You guess which 4!
My BT1:
[SIGPIC][/SIGPIC]
