Results 1 to 12 of 12
Thread: Tranny Problems
    VS Commodore S2 Ex cop
    Jan 2009
    Default Tranny Problems
    Hu guys. Ide thought ide drop a question in here.
    I was driving my VS around on Friday night when all of a sudden i started smelling burning oil... I stoped to check the engine and it seemed fine, oil was there.
    I kept driving and eventually after stoping at a traffic light i noticed that ide put the peddle down... but the wheels where moving.... "WTF" needles to say was my first reaction.
    I drove into a shopping centre poped the hood and checked the tranny oil. Nothing in there. so I bought some tranny oil and filled her up. the engine warrning light is still on and the car still doesnt move like it should.
    You take off in D and it feels like its only in third gear. But going down the gears help.
    Only thing i can think of is a broke a seal and oil isnt going to the tranny propperly and instead is getting burnt up on my exuast.
    Any one have any ideas? theres still a faint odhour of oil burning and redish (tranny fluid) spots on my concrete.
    If it is just a seal. whats the best way to get it fixed?
    woteva's Avatar
    woteva is online now NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Quote Originally Posted by Lupetto View Post
    Sounds like you need to take it to a Tranny specialist.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Jan 2009
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    ive had a simular problem only it was more severe. I had a hose pop off and i left a whole expensive trail all the way to the servo about 1.5 km away. Well the car wouldnt get out of first gear and acceleration wasnt there. Once i got to the servo i tried to move up to the pump and the car just revved and barely moved. Basically the torque converter wasnt delivering the power to the wheels due to no fluid.
    Best thing to do is get under the car by using some ramps or a good trolley jack with jack stands (if i see u not using jack stands i will kick ur arse! ) and see where the fluid is coming from. My problem was simply a worn hose clamp, $2 at Mitre10.
    here was the aftermath:
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Jan 2009
    hey thanks. Yea im waiting for my cuzin to bring back my ramps. Once he gets here gona check out and HOPE that its only a hose or something.
    Jan 2009
    well i got under there. The pump hose isnt loose theres nothing loose that you can phisacly see or feel unless you start to dismantle things. Feels like pump isnt working in Drive. A little oil drips but very LITTLE like a drip every 30-40 min. Ive ran out of ideas. Ive been told its safe to drive in 1st 2nd and third untill i get it fixed. Any one here have any more wood to throw in the fire regarding this issue?
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    It may only be dripping when stopped but who knows how much oil pressure is lost when giving it a boot down the road. Wouldnt hurt to get a trans service, $120 it cost me and they do the fluid and the filter and they see wats wrong with it professionally.
    Jan 2009
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Where bouts did you get done yours at?
    In Victor Harbour SA but i cant remember the place sorry. If u are near the bottom of the Peninsula in SA i can give u their no.
    vt 3.8 ltz
    Aug 2008
    hi i also had the same problem with my vt and the cure was the cooler pipe from the tran was leak and spraying oil on the exhaust.
    when you fix ur tranny's problem please let us know wat was it??????!!!!!!!!!!!!!
    Jan 2009
    At the moment it sounds like its a solenoid. Going to a Tranny specialist most prob tommorow arvo to get it checked out. Will post more info as i go allong.
    Jan 2009
    Yep was a solenoid (the shifter one)
    Getting it replaced and Tranny flushed.
    Thanks for your help guys.
  1. 92 vp tranny and spedo problems
    By cavantrev in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2008, 10:01 AM
  2. vs v6 tranny gone?
    By lumina01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2008, 11:48 PM
  3. tranny
    By kurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2006, 07:47 PM
  4. Which tranny for my VK
    By HSVbenno82 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-08-2005, 02:42 PM
  5. tranny
    By freddy69er in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2005, 12:05 AM
