Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Haydz
Thread: possible fuel pump problem? please help!!!
    VS V6 5SPD UTE
    Jan 2009
    Default possible fuel pump problem? please help!!!
    my vs ute isnt starting anymore, but before this happened i would have a problem where if i put the foot down just even a bit the fuel would cut off and id end up stalling, this eventually got worse and would happen if i tried to baby it. Now it wont crank over. When i go to crank it i wait for the noise of the fuel pump, but instead of hearing the normal noise, it sounds real rattely. I replaced the fuel filter, and ran a fault test and came up with fault code 12 (everything ok) , to me it would seem the fuel pump but the rattely noise seems to becoming from the throttle body area so its got me bummed! anyone have any ideas and if it is the fuel pump where its location is on the utility, it deosnt say in my workshop manual, but i heard it may be under the floor pan of the drivers seat and the tank has to be dropped, thanks for your time!!
    None
    Aug 2005
    Adelaide, SA
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    hey mate sounds like the fuel pump is on its last legs.
    a few things you could try
    replace the fuel filter. and have a mate bang on the tank as you try to crank her over.
    also make sure there is fuel in there. the gauges have been known to lie.
    and if not i would be changing the fuel pump. and it is inside the fuel tank.
    you need to drain all the fuel and the fuel tank is in the tray. close to the cabin. there is like a panel with a bunch of screws holding it down.
    VS V6 5SPD UTE
    Jan 2009
    Default !
    sweet cheers guys, i took that panel in the tray of this mornin haydz, so all i do is drain the fuel and open her up i guess to change the pump, hopefully i get it all going ill keep ya posted cheers!
  1. Vr Fuel Pump Problem help
    By [QW-11-KE] in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2012, 06:19 PM
  2. Fuel Pump Problem?
    By Swift in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2008, 08:46 PM
  3. fuel pump priming problem
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2006, 11:57 PM
  4. problem with fuel pump or tank
    By SaGe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 02:19 PM
  5. VX Excex fuel pump /LPG problem
    By tiges1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2006, 06:56 PM
Tags for this Thread
