Results 1 to 6 of 6
Thread: Air bag light wont go out
    Razedaze is offline Razedaze
    VS Berlina
    Jan 2009
    Banks Peninsula, New Zealand
    Default Air bag light wont go out
    I have a '96 Vs which had been dumped in a paddock 2 yrs ago, have got most of it working but I am flustered over the srs air bag light wont go out. Is there an easy fix or will I have to fork out for the dealer to fix it? I have tried disconnecting the battery as advised and standing on the brake for a while, still no effect.
    James_yo7's Avatar
    James_yo7 is offline Barbitaboopey?
    2008 LUX minitruck
    Feb 2007
    Melbourne, Vic
    VR Caprice
    Dec 2005
    Disconnecting the battery wont make the Airbag light go out, you need to go and have it done at a dealer. Dosnt have to be Holden but they must have the tech 2 to access the computer.
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    There will be an error in the Air Bag system, hence why the light is staying on. It could be the clock spring behind the steering wheel, often these break. As soon as you can get it hooked up to the TECH II system, you will be able to find out exactly what the problem is.
    VRII Acclaim
    Jul 2005
    Yep off to the dealer. They can check for the fault, if there is no fault they can clear it. If you turn the car on while the instrument cluster is out you will activate it.
    VS Berlina
    Jan 2009
    Thanks guys, Have been to the dealer and had it cleared, Grand total $75 later. The coil spring is not a spring at all, it is a coil of cable designed to allow for travel as the stearing wheel turns,If anyone else wishes to play with this item I suggest they read the instructions very carefully as misassembly could cause all sorts of problems. Anyway, all fixed now, thanx again.
  1. Interior Light wont turn off!!
    By GIMPY1 in forum Electrical Wiring / Questions
    Last Post: 21-01-2008, 08:32 PM
  2. battery light on and car wont start
    By ducki in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2006, 03:50 PM
  3. Put new bootlid on, now interior light wont go off
    By andy05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2006, 02:24 PM
  4. light in car wont go off
    By VLACS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-08-2005, 07:52 PM
  5. vn oil light on now wont start
    By william19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-06-2005, 02:59 PM
