Results 1 to 6 of 6
Thread: How to install a tow bar on a vr wagon
    vr BT1
    Oct 2007
    Default How to install a tow bar on a vr wagon
    Got a hayman reece tow bar and just wondering how to install?
    do i drop the fuel tank out or take the rear bar off?
    any help would be great, thanks.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Only advice I can give you is to lay the towbar on the ground directly under where it will attach to the car. Then mentally raise the bar and visualise/figure what holes already exist and what ones need to be drilled (if any). You may find instructions at the HR website. Don't think you will need to pull the tank.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Not sure mine just had a tow bar in when i bought it. Under the back i did notice some bolt heads for it, and i cant imagine they were there before so i think they drilled them. But unfortunatly i cant be much more help than that.
    Reaper
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Starkey View Post
    I have done so any question just ask
    But no need to remove rear bar or fuel tank..
    Your tow bar should have come with 2 top plates which sit on the floor under the carpet, bolts with sleeve/spacers and the towbar itself.
    Its much easier with two people, but underneath you will see holes, get a centrepunch and line it up inside the holes, use a hammer and give it a decent hit, you should see punch marks where you need to drill your holes!
    One of the holes on the drivers side actually shares the bolt for the fuel tank strap (You will see the nylon washer that it replaces) so make sure the tank is supported when you undo this bolt.
    Get someone to support the towbar underneath while you drop the bolts through, make sure you use the spacers on the bolts and tighten everything up.
    Thats about it, have fun.
    vr BT1
    Oct 2007
    thanks for the replies tow bar all done now for the wires. i have bought the wires from super cheap. is there an existing loom in this model?
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    I believe you can buy the proper loom from GMH. It is only a short one and plugs into the brake/tail light/indicator loom. To access it you need to remove the panel that covers the rear right hand side speaker. It is held in place with a dozen of so plastic clips that just pull out. Once you do that you will find the loom socket near the tail light assembly.
  1. One amp or Two for new install
    By Wojzilla in forum Car Audio
    Last Post: 22-12-2008, 08:00 AM
  2. install in rear of wagon
    By clyde in forum Car Audio
    Last Post: 02-11-2007, 12:45 PM
  3. Help! Where to install battery in VS Wagon
    By nuga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2007, 12:38 PM
  4. Manual VT wagon or VX wagon + conversion?
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2006, 11:09 PM
  5. How to install a rear wagon window???
    By Mick Molloy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 12:46 PM
